1 - 15 of 15 Posts
Retired
Yesterday I was pretty ill so I let my computer fold all day. This was my first day letting her fold at some preliminary underclocked and undervolted settings, I still need to dial in the voltage-frequency curve but as it is I have dropped the at load wattage from ~380 down to ~280 which has seen the clock speeds drop from ~1950 to ~1860. There's still much more to tune, I expect I'll be able to drop another 20 or so watts while maintaining or boosting the average clock a little bit more when I have the energy to fiddle w/ the voltage-frequency curve. Anyways, here are the first uninterrupted 24 hours I let the 3090 fold at. Total PPD @ underclocked settings: 6,425,463
2461115
~6.5 milly a day... that's alot!
think i brought a butter knife to a gun fight.
my whole system avg is 400~500k a day
With what hardware? Do you have a passkey set up with bonus points active?
What were the temperatures?
Retired
Discussion Starter #8
Temps are pretty damn low, ~57c max at the undervolted/underclocked settings. The cooler on the 3090 TUF is pretty beefy and having two 120s right below the GPU certainly doesn't hurt.
Reactions: chris89
I <3 narcissists
That's pretty darn good.
For perspective, my 2080ti and 1080ti (both stock settings) will do about 6.4 mil ppd if I let them run uninterrupted. It takes a good bit more wattage for me to get that 6.4 mil though (500-ish watts).
Thats ridiculously low temps & even the FE card hit 72*C under load but maybe 3d load is different than folding?
Retired
Discussion Starter #11
Folding load is pretty variable depending on the WU and how much of the GPU it can use. Some WU's only peg my GPU at 80% load with temps around 53c, while the ones that show ~95% utilization hit 57c at underclock/undervolt and 60c w/ an overclock and 107% power limit. Keep in mind the Asus TUF 3090 has a power limit of ~375 watts whereas the FE cards I believe go up to 410 watts, that's another 35 watts of heat the FE cooler has to dissipate w/ one fewer fan than the TUF. I also run the Lian Li 011D w/ 3 120 side (back) intakes, 2 120 bottom intakes, and 6 120 exhausts on the push/pull 360 rad up top, so there is a bunch of air flowing through the case. Recently I attempted (and failed, infuriating) to hit 20k on time spy and during my attempts, I took the front/side panel off the case and pointed a Vornado desk fan under the GPU in an attempt to bring the temps down as much as I could and only saw a 6c drop at load for the temps, the airflow in the case is just that good.
Reactions: chris89
I <3 narcissists
I tried the same thing with my O11D. I was glad it's didn't make a big difference in temps because taking off the side panel surely made a difference in noise.
I have noticed the variability in loads depending on the work unit. There are some work units that give me some coil noise as well, I hate those work units. Those coil whine work units are causing me to second guess my open bench idea for a folding rig.
-6*C is quite a big reduction though from a desk fan helping but yeah sounds like u have some amazing airflow.
I <3 narcissists
Do you have the passkey or whatever it's called?
1 - 15 of 15 Posts
