Sky, do you have any idea why my power balance is like this?
I did some calculations, versus my Timespy scores I got on a STOCK card at 440W (114%), (pure stock, unopened, no changes in thermal pads/paste/shunts) with +100/+600, and I determined that to get the exact same scores (currently, post all mods and re-pads, repastes, etc), I need a 69% power target. Then, I took the GPU Board Power value shown in GPU-Z and in order to get 400W from the 69% run (which gave the same scores, about 21,015 Graphics score in Timespy), I need a
1.65x multiplier! 1.65x multiplier with paint? (GPU-Z reporting about 245W total board power for 12,015 graphics TS score). Okay....anyway....
Edit here is proof of that (although I don't have the original pre-mod runs, they are on my 3dmark history).
69% power target, +90 core, +500 memory.
Compare this to my "best" full run TS score before I got the paint (I got the paint on November 4th. this run was on October 25th.
21,022 graphics. +100/+600, 400 watts (114% TDP)
The absolute maximum graphics score I got (custom run, graphics test only) pre-mod was this one: 21082.
Take alook at this now.
This is my timespy and port royal run from this morning.
Note that I got these same scores (actually slightly better TS) when the mod was first done, back on november 11th, when the 8 pins reported balanced power draw.
Although here i'm at +150/+500, and was then at +150/+600.
So anyway...
My scores are the same, and I did a "Heaven" 1080p run last night and it seems I can reach 535W of power before hitting a "power limit" with the power slider at 114%. However the difference now is that the card apparently isnt "maxed out" and is hitting this "Unthrottled" limit, only if "Normalized" TDP is under 114%, while the total TDP is much lower (not even 100%).
It seems that "total TDP" only reaches 100% when I get close to 570W! But then some heavy throttling starts happening when 8 pin #1 gets to its power limit of 175W in GPU-Z...
Ignore the "throttle" and "Thermal" limit flags --you can see that "blip" on GPU-Z--this seems to be a bug in the latest Vulkan beta drivers. Doesn't happen at all in 456.98 Hotfix.
As far as those limits---here is a "High temp" 4K overwatch run from last night. Very high temps so clearly that power draw is pretty accurate.
You can see the throttle bar not being 'full size'--meaning the throttle warning flag was enabled because a power rail was approaching its limit. I actually saw up to 572W, but by this time chip reached around 80C so I stopped testing.
Anyway---back to the point:
What's going on with the 8 pin #1 and #2 and PCIE Slot readings here?
It's like the board seems to be 'normalizing" (TDP) itself based on close to 15 mOhms stacked (3.75 total shunt resistance=535W at 114% TDP), then showing throttle flags after that is exceeded.
@bmgjet said that the board is drawing heavily from 8 pin #1, because of me using new higher quality thermal pads. However why would it draw SO MUCH from 8 pin #1? That's a pretty huge balance difference.
Note that several days ago, I actually threw on a 5 mOhm shunt on top of the paint on the "Right side" shunt of the two 8 pins (I do NOT know which shunt is for 8 pin #1 or 8 pin #2...
@olrdtg have you done your testing?) and it made NO difference in the power balancing! Then two days ago, when I got my Kryonaut Extreme paste, I threw a 5 mOhm shunt on top of the "other" (left side) 8 pin shunt! And still no difference in power draw balance!
So the power mod is working, the board seems to be drawing proper power, but reporting it in a VERY unbalanced way. And Overwatch being able to pull 570W on air....
Opinions?
