So it looks like I FINALLY fixed the power balancing. Got the TDP% to actually be calculated correctly and now shows up as TDP Normalized 104.6% and TDP 98.2%, looping Heaven.
Working a lot better than before, GPU Board Power is actually in good balance now, and I'm able to pull as much as 570W (estimated from my kill-a-watt) from the video card in Timespy.
I only hope it remains stable and doesn't start acting strange with time...
Port Royal run. notice the normalized is no longer at 114% (my power limit is at 114%). So a lot better than before.
So here is what I did.
I scraped the two 8 pin shunts and cleaned them. This took HOURS. And I had electrical tape (Super 33+) around the board so I wouldn't scratch anything with the mini screwdriver. Not only did scraping take hours, I then had to clean the paint residue on the PCB that got under the tape, since I had to use alcohol to loosen the paint (some of it was IMPOSSIBLE to scrape otherwise). Again--I've asked multiple people here which shunt is 8 pin #1 and which is 8 pin #2, but yet no one seems to know at all. (how can you guys not know? Some of you guys have probing equipment). Anyway...
After the shunts were cleaned and silver shiny, I put a nice glob of paint over each of the contacts on the depressed edges (it sucks that FE shunts have the edges lower than the housing middle section), then I stacked a 5 mOhm shunt on top of it and pressed down firmly. With my Super 33+ tape protecting the PCB, I felt a lot safer about that. Then after it dried a bit, I coated the top and side edges of the "silver" part of the shunt with the paint, and tried to bridge it with the bottom shunt. There was barely any room to work with and plenty of paint got on the Super 33+ tape in the process.
After reassembling, results were at first awful (I only gained 40W from 400W on my kill-a-watt) but over the next hour, this slowly rose to about 500W (+100W). It briefly got a little better from there (KAW briefly registered 720W total), but then seemed to get slightly worse then tone down at 500W total (690W wall). And Heaven was mildly power throttling down to 2055 mhz and 1.038v, which I didn't like.
So I had a big brain moment last night.
I asked...well....what if I coat and bridge the top of the NEW shunts? If the entire circuit is acting like a modified shunt as is, then coating it fully should drop the resistance even more! The exact same way that coating the original 5 mOhm shunt without stacking lowers the resistance, but to less effect of course. I mean, this IS a science, right? Why would it not work? Scientific rules can't be broken...
So I coated and applied another layer on the silver edges and bridged them through the middle firmly...
And so far, success. (Depends how long it lasts...we all know these mods seem to work for awhile and might suddenly have an 8 pin or PCIE suddenly skyrocket to 175W or 79W....)
The drop in TDP Normalized% is the huge giveaway here. Instead of it being at my TDP slider (due to power rebalancing from the high 8 pin #1), it's now a lot more level, and Total Board Power is also reporting a bit higher than before.
