1 - 17 of 17 Posts
cd C:\TEMP\
K... so my Q6600 is still running stock due to it hitting 60degC on the cores when stressed... but it must be OC damit
Raidmax Smilodon case with a Thermaltake Ruby Orb cooler...any suggestions on what would be the best bang for buck to get this sucker cooled properly?
Thx
cd C:\TEMP\
Never heard of Xigmatek till now... quick search and this is what I found to get it in South Africa... problem is it will cost me $138.79... ***!?
That is more than all the stuff below
Originally Posted by Tator Tot View Post
If you want to spend some, I would say get 2 Scythe Ultra Kaze fans, a 4 channel fan controller and a Xigmatek HDT S1283 all in an Antec 300 and a retention bracket
Antec 300 $50
3x Scythe Ultra Kaze 120mm Fans $30
Xigmatek H.D.T. S1283 $32
Xigmatek Retention Bracket $7
Sunbeam Rhobeaus 4 Channel Fan Controller $20
Originally Posted by Marin
It would be better to get a Thermalright Ultra-120 Extreme, they cool better on quads than Xigmateks do.
The TRUE is twice as expensive once you factor in buying a fan though (And probably lapping sandpaper too)
You gotta pay for the best
A Noctua NH-U12P is a good alternative if you can't afford a complete TRUE
cd C:\TEMP\
... thx for all the input... the scary thing is the TRUE plus a fan is actually going to cost me less than the Xigmateks I can get here in SA...
How so the Xig is 20 on newegg. True plus fan has to be close to 80 if ou get a good fan.
Originally Posted by sLowEnd View Post
I'm 99.9999% sure newegg doesn't ship to South Africa
Newegg needs to go global...just sayin...at there prices...it would be no contest.
cd C:\TEMP\
Discussion Starter · #16 ·
QFT :swearing:
1 - 17 of 17 Posts
