hi, some friend is talking about flashing a mars 760 into GTX690 and geting all the cuda cores unlocked.
i hate this kind of Rumors .. i spent about 7 hours trying to find a trace for this news ... nothing out there .
here what he did say :
please check the card they are 100 % the same
mars 760
GTX 690
if anyone can confirme this or try to give me a mars 760 bios
i will buy a mars 760 and test this !!
guys is this realasus used the same PCB of 690 and the same Gk 104 with full 1536 cores
the 2 cores on the mars 760 was not laser cut or hardware locked
the bios is the same as a 690 it's only modified to work with 1152 CUDA cores
put bios files into a hex editor , and you will find the same hex values and only the device ID is changed along with clocks and other stuff ...
this take us back to the GTX 465 flashed to 470 thru bios .
take a closer look to both PCB
if the mars 760 was fully locked you will never find the same compounds as GTX 690
to disable a part of the core in Gk 104 you have to cut up the power for that disabled part
you will find both card have the same power watts ...
flashing the mars 760 have the same process as the GTX465 to GTX 470
you will have all full 3072 cores but with more oc capacity thnx to asus power chokes
mars 760
GTX 690
