1 - 8 of 8 Posts
Not new to Overclock.net
Discussion Starter · #1 · (Edited)
2487208
I'm getting closer to installing Windows 10 fresh on a new drive, and I want to achieve what you see in the screenshot again. Only, I forgot how I did it. Can you help?
I get this when I press WinKey+R. I had to do something to make it be this way, but I don't remember what it was. I want this for my new installation of Windows, whenever I start doing that.
Edit: I don't want some alternative way to do what this does. I want this. I want my Run dialog box to look like this every time I access it.
Update:
I figured it out. I had a feeling that I would figure it out after asking. Isn't that how it goes sometimes? :)
In the Registry, you go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System and change EnableLUA to 0. The default is 1. Reboot, and it's done.
I wasn't figuring it out before because I kept asking Google various kinds of questions that I thought would lead me to the answer. I never just simply Googled "This task will be created with administrative privileges". Once I did that, I found the answer.
Reactions: Iconoclast
Graphics Junkie
task manager > file > run new task > check the box.
Graphics Junkie
That's not the question. Try again, my friend. lol :)
Yea I'm not sure how to get there without the checkbox but the result is the same.
There isn't a checkbox. I want this to be like this every time I press WinKey+R.
I guess I'd better make that more obvious.
To launch an app with admin rights, type it in and press Ctrl + Shift + Enter
No idea how to make that dialog show up permanently.
Reactions: Techie007
Reactions: T.Sharp
Windows Wrangler
Didn't know this trick—thanks for sharing! Now why Microsoft removed the checkbox option from the Run dialog when opened from the Start Menu while leaving this hidden shortcut functional, I will never understand. Once the option was removed, I've gotten to it through Task Manager, which is a pain.
1 - 8 of 8 Posts
