1 - 18 of 18 Posts
Ok I installed 2x1gb Crucial Ballistix DDR500 RAM but I'm running them @ DDR400. It's rated at 2.8V with 3-4-4-8 timings. Do I need to set the voltage to 2.8 even @ DDR400? And can someone please describe what each number is in the timings are. I know the 3 in 3-4-4-8 represents CAS Latency, what about 4-4-8? I really don't know what to set my memory in BIOS at. Thanks for taking the time to help.
Since you are currently running the memory at ddr400 though rated at ddr500 you could drop the vdimm a bit but more favored would be leave the vdimm where it is and tighten the timings up since amd cpus like tight timings while intel doesnt realy care about timings. Heres a faq to hopefull answer all your questions about what all numbers mean http://www.overclock.net/faqs/26706-...s-dummies.html
Depending on how high you push the CPU OC you may need to up the voltage.
The RAM speed increases along with the CPU bus speed, so tightening the timings will reduce the overall OCing of the RAM as will the lower voltage setting.
BTW, get CPU-Z @ www.cpuid.com to compare your RAM timings and other things!
Discussion Starter #4
Alright under SPD tab in cpuz it says timings table 250mhz 3-4-4-10
And when I go to the Memory tab it says 201mhz 3-4-3-8.
I get the "200mhz" 3-4-3-8 timings when I set to optimized default in bios. Now the strange thing is on crucial.com website, the memory's timings are 3-4-4-8. http://www.crucial.com/store/partspe...L2KIT12864Z503
Just to let you guys know, I've run memorytest86 for 1 hour 44 mins on the 3-4-4-8 timings, passed. Ran 2.753ghz OC with 3-4-4-8 timing on prime95 for 4 1/2 hours fine. So my question is, what should I set my timings at?
Make it run at DDR500 (250FSB) and 3-3-3-8, it should say on crucial site and on the ram itself and 2.8v.
Discussion Starter #6
Where'd you get 3-3-3-8 from? The website says 3-4-4-8.
Overclock Failed...
The 3-4-3-8 ... what are the posted timings at DDR400 in the SPD tab of CPU-Z? The timings will tighten up in lower speeds, that is what the SPD does, set timings at various common default speeds.
What I don't know is what speed the RAM was running @ when you had an OC of 2.735GHz. So, I can't offer much if an opinnion on what timings to use.
Discussion Starter #10
Regardless of what FSB I'm running the SPD tab will say 250mhz 3-4-4-10. My motherboard defaults the RAM @ 200mhz 3-4-3-8, when I manually set everything back to default.
I'm tired of messing with it. My BF2 runs @ 99.9 FPS(max set to 99.9 FPS), and 95-99FPS under load. My guess is the 3-4-4-8 timings @ 250mhz are fine.
Overclock Failed...
SPD timings have nothing to do with how fast your memory is running. Use CPU-Z.
Discussion Starter #12
I do use cpu-z, and have used it since forever. If you've read the previous posts, I stated that the speed timing of the memory was set to 3-4-3-8 when I set everything to default in bios. When I do that, the memory is set to DDR400 with 3-4-3-8 timings. I manually set the speed to 250mhz and 3-4-4-8. k thx.
It would be worthless to OC the ram if the chip isnt OC'd. You get no gain with a higher memory clock on a stock chip.
pink
pink
Hey DOS Fuegos...and yes P57 told you what is the truth...OC RAM and not the PC is a not-gonna-get-anywhere
pink
why is it worthless?, memory timings and clocks do make a difference on a stock CPU, it is only the memory speed thats higher, and all memory sensitive programs will benefit from it. Like a graphics card only works for games and will notice not much speed increase, (in XP). the only downside is, that your gonna have to find the best setting for the multiplier and divider, in your system....but correct me if im wrong....
Your CPU has to try and keep up with your RAM and its getting nowhere fast my man. Tighter timings I say go for but forget trying to OC the ram without the CPU.
Prob I swear you are following me lol
pink
And a stock CPU speed with some tweaks elsewhere...is running fast?
I hope that is a hypothesis and not a conclusion...
On a o/ced conroe or allendale chip timmings dont matter SOO much but on a AMD 64 chip then timmings are everything for speed ..To get the best out of the ram and chip the fsb needs to be set at 250mhz then your ram will run at it,s stock settings ..TRY THIS multi lower to 10 set fsb to 250 dont alter v-core as yet ...This will allow your ram to run at it,s stock values of ddr 500
1 - 18 of 18 Posts
