Running motherboard out of case
1170 9
Hey guys... I was just about to setup my rig on the desk (please don't ask why) and I was wondering if there is any special grounding or shielding needed? I was planning on just setting the actual motherboard on a thin piece of foam on the counter. Will this be OK? Might the foam melt to the motherboard? Should I put it on an anti-static bag too? I've never done this before and I don't want to find out what happens the hard way
1 - 10 of 10 Posts
What is the temp of you computer now? any advantages to running it out of the case? One thing to consider though is you'll have to clean it more often, to get the dust that would normally settle on the case, but now onto the motherboard directly.
So far the cpu temp is about 2C lower and the video card is 10C lower. Not a big difference but it's going back in the box as soon as my MATX mobo comes back from RMA.
1 - 10 of 10 Posts
