1 - 4 of 4 Posts
I'm gonna need a sweeper
You might be able to use the SLI hack to run SLI on that board. If you just want to run 1 460 and another card for physx you will be fine anyway I believe.
Originally Posted by Binnz
I have Gigabyte P55A-UD3 motherboard which supports CrossfireX but no sli.
So i am wondering can i run for example GTX 460 and use 9600GT for PhysX ?
Best Regards
Binnz
What games are you playing? This is a fair bit of hassle and only 20 titles can actually use GPU-based Physx. Unless a game you are playing is listed here:
http://physxinfo.com/data/vreview.html
then there's no point in using a GPU for Physx. 95% or so of titles that use Physx can only do CPU-based.
1 - 4 of 4 Posts
