1 - 9 of 9 Posts
hi guys i am going with push and pull fans on my rx360 radiator and want to know what size of screws will work with it .
i checked on the website and it only says 6-32 case and fan screws don't know what that means
i took the current i have to a few hardware shops and they dont have the same size
any advice where i can buy online ? ebay will be preferred
thankyou
Pigeon Poop Enthusiast
thankyou
These are the ones I purchased some time ago,
http://www.mcmaster.com/#catalog/119/3079/=loy5jw
I also ordered these though not sure why. Might have been as a back up in case the 1 1/4" ones were too long.
http://www.mcmaster.com/#catalog/119/3079/=loy5vk
It uses UNC 6-32 screws. The "6-32" is the threading type.They have the same threading as the screws you use to mount hard drives and PSU's. If you're mounting 25mm thick fans, get 30mm long screws. If you're doing fans plus a grill, get 35mm ones.
Can u give me a direct link to the screws I don't quite understand the link u gave me has a long list of screws I don't know which to choose I am going to use these gts with the rx 360
http://www.ebay.com/itm/310389030988?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Already bought 6 of them can u send a direct link to the screws
The radiator uses 6-32 threaded screws. Since the fans are 25mm thick you'll need 30mm screws which is around 1 1/4".
Alternatively, you can buy 50mm nylon screws and then cut them to whatever length you need.
1 - 9 of 9 Posts
