Hello Guys,
Finally AMD is back in the market!!
So I'm building a Ryzen 1200 system with following main components. I have couple of questions listed below. I will be grateful if you can answer.
AMD RYZEN 3 1200 4-Core 3.1 GHz (3.4 GHz Turbo) Socket AM4 65W YD1200BBAEBOX Desktop Processor
https://www.newegg.com/global/in/Product/Product.aspx?Item=N82E16819113446&ignorebbr=1
MSI B350M Gaming PRO AM4 AMD B350 SATA 6Gb/s USB 3.1 HDMI Micro ATX AMD Motherboard
https://www.newegg.com/global/in/Product/Product.aspx?Item=N82E16813144019&ignorebbr=1
G.SKILL Ripjaws V Series 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z170 Platform / Intel X99 Platform
https://www.newegg.com/global/in/Product/Product.aspx?Item=N82E16820231939&ignorebbr=1
EVGA 450 B3, 80 Plus BRONZE 450W, Fully Modular, EVGA ECO Mode, Compact 150mm Size, Power Supply 220-B3-0450-V1
https://www.newegg.com/global/in/Product/Product.aspx?Item=N82E16817438124&cm_re=psu-_-17-438-124-_-Product
[1] Most importantly at the moment I am little low on budget so can't buy a new GPU immediately.
. Fortunately I have one old GPU(old means ****ty old
) GeForce 9500GT.
Will it work with above build?
[2] Then your thought on above components...
[3] Finally future plan is buying GTX1050Ti. Any suggestions on this?
