1 - 3 of 3 Posts
Only ran Prime95 for a half hour, so I may not be "rock solid".
I have Gigabyte Aorus X370 K7.
Vcore - 1.375v
Vcore SOC - 1.2v
CPU VDD18 - 1.920v
LLC - "Turbo" (Whatever Turbo means, heh)
Highest Vcore I saw was 1.416v. Is that an average amount of variation from the vcore with LLC enabled?
Temps after that half hour were 68-69c
Is there a chance I could hit 4.1? Worth it?
See here for HWmonitor, CPUZ, and p95- https://imgur.com/a/z9mmy
I posted this elsewhere as well, as I kind of want to soak up some knowledge if possible. I spent about 4 hours OC'ing from 3.9 to 4.0. What a marathon.
depends on what you think worth it means. I can get 4.0 but the heat on my B350 tomahawk VRM's isn't worth it. significantly more power just for a few extra points in cinebench and an insignificant reduction in video render.
1 - 3 of 3 Posts
