1 - 11 of 11 Posts
Discussion Starter · #1 · (Edited)
The System
SeaSonic X750 Gold 750W
MSI X370 XPOWER Gaming Titanium
Ryzen 5 3600 2010SUS
Viper Steel Series PVS416G413C9K
Asus GTX 780 DCII OC
Samsung 960 EVO 500GB
EK-FB MSI X370 XPower RGB Monoblock 1/2" ID | Swiftech D5 MCP655 | EK-XRES 100
Alphacool NexXxoS UT60 280 | 4 x Scythe GT AP-15 @ 5v
Thermochill PA120.3 | 1 x NF-A12x15 | 2 x ML120 | PWM
Software
BIOS: 7A31v1MR
Operating System: Windows 10 1903 (OS Build 18362.900)
AMD Chipset Drivers: v2.04.28.626
Power Plan: AMD Ryzen High Performance
Voltage Settings
vSOC - Offset Mode, -0.0375v, LLC Mode 1, 1.072v (BIOS Reading)
vDDP - 0.995v
vDDG IOD/CCD - 1.025v
vDRAM - 1.50v (1.520v BIOS Reading)
Digi Settings
CPU Overcurrent Protection - Enhanced
CPU Switching Frequency - 300 Khz
CPU NB Overcurrent Protection - Enhanced
CPU NB Switching Frequency - 400 Khz
DRAM Overcurrent Protection - Enhanced
DRAM Switching Frequency - 375 Khz
DRAM Phase Control - Disabled
CPU Settings
Global C-State Control - Disabled
Spread Spectrum - Disabled
AMD CnQ - Enabled
SVM Mode - Enabled
Power Supply Idle Control - Typical Current Idle
CPPC - Enabled
CPPC Preferred Cored - Enabled
Baseline Settings
CPU vCore @auto
BCLK @106.875 mhz
CPU Boost @150 mhz
All other settings refer to screen shot
Discussion Starter · #2 · (Edited)
65W Default vs EDC @3
Comparison of
CPU vCore Auto, CPU LLC Auto, BCLK 106.875 mhz, CPU PPT @88w, TDC @60a, EDC @90a, CPU Scaler @auto, CPU Boost @150 mhz
vs
Exact same settings but EDC @3a
Discussion Starter · #3 · (Edited)
105W Default vs EDC @3
Comparison of
CPU vCore Auto, CPU LLC Auto, BCLK 106.875 mhz, CPU PPT @142w, TDC @95a, EDC @140a, CPU Scaler @auto, CPU Boost @150 mhz
vs
Discussion Starter · #4 · (Edited)
105W_EDC @3_LLC-Auto vs LLC-Mode2
Comparison of
CPU vCore Auto, CPU LLC Auto, BCLK 106.875 mhz, CPU PPT @142w, TDC @95a, EDC @140a, CPU Scaler @auto , CPU Boost @150 mhz
vs
Discussion Starter · #5 · (Edited)
105W_EDC @3_LLC-Auto_CPU-Scaler-10X vs LLC-Mode2
Comparison of
CPU vCore Auto, CPU LLC Auto, BCLK 106.875 mhz, CPU PPT @142w, TDC @95a, EDC @3a, CPU Scaler @10X, CPU Boost @150 mhz
vs
Exact same settings but LLC Mode 2
Discussion Starter · #6 ·
Reserved 6
Reserved 7
Discussion Starter · #8 ·
Reserved 8
Discussion Starter · #9 ·
Reserved 9
Discussion Starter · #10 · (Edited)
Will add more data,
Want to test with vCore offsets also.
What I learned in general.
LLC plays a huge role in normalizing CPU clocks when all threads are loaded with "heavy workloads" when using the EDC bug.
When the EDC bug is not induced, CPU clocks are all normalised automatically when all threads are loaded with "heavy workloads".
You can use EDC bug with LLC on auto and will downclock "weaker" cores automatically when using "heavy workloads".
Using different levels of LLC with the EDC bug you can effect by how much the weaker cores downclock
:p
Data with regards to CPU Scaler is to show the effects on vCore, and current.
I only provided thermal data for the worse case scenario, that is Prime95 Small FFTs.
All other tests remained below 76C on my cooling setup.
Of course, this data is relevant to my PC which is using an x370 motherboard.
Any other data can be added by whoever wishes.
If you can keep it in the same format would be great
:D
*heavy workloads, AVX2, FMA3 etc etc
Keep us updated! Would love to use your settings on my setup since our CPUs are pretty similar. I've settled on 4.4Ghz all-cores but might want to give this a try. I updated to the latest bios for my board so hopefully the bug still works.
1 - 11 of 11 Posts
