Hi All,
This is my first post
I just overclock my ryzen 5 1600 to 3,7 Ghz , Stock cooler.
VCORE voltage , set to minimum offset +0.00625 (if i am not mistaken), as my research some people can run it on stock voltage stably
SOC voltage, i left it to auto 1.100 V
I run Cinebench over and over, no crash
Then run Prime95 for around 3 hours, the max temp reach 84C, no crash
What you think?
Is that temperature normal? My chassis fan is 2 intake, 1 exhaust and the ambient temperature here is quite high around 30C ( i feel sweat without blower)
And somtimes i feel like my mouse lagging. is it caused by insufficient voltage ? should i add more voltage to get more stable ?
Thank you
What you think?
Thank you
