1 - 13 of 13 Posts
Hi there
Long story short ... new system:
Ryzen 5 3600
Gigabyte B450M Aorus
2x8 Gb DDR4 3000
Windows 10 1903
Latest Chipset drivers
Latest bios with AGESA 1.0.0.3 ABB
Cinebench scores are 2950 for CPU and bellow 400 for single core. These are very low scores, right ?
What I tried:
PBO on and off, tested both.
Different power plans.
Reinstalled drivers, updated bios (before was with AGESA 1.0.0.3 AB)
Temps are fine. The CPU hovers around 70C in full load (I'm doubtful about this since until I get a better cooler than stock I'm using a low profile ID Cooling IS-40V3 ... but well, that's what the readings say).
VRM temps are fine (around 40C to 50C in load). Everything is fine, nothing should throttle.
Despite that ... the system doesn't perform well.
Any ideas please ?
PS: Screenshots uploaded but with the latest bios reset I forgot to enable xmp. The ram is running at 2666, not that it did any difference.
Try resetting your BIOS to Optimized Default. Go back to Windows and do not open Ryzen Master. Close all other monitoring apps like HWINFO, then run Cinebench again. Don't worry about RAM for now.
Tech Enthusiast
Hi there
Ryzen 5 3600
2x8 Gb DDR4 3000
Windows 10 1903
What I tried:
Any ideas please ?
So I don't have that board, or That CPU, I run with a 3900x, but I am pretty sure I know your issue. PBO is pretty broken right now, especially on ABB, although AMD Won't admit it. You might be able to get someone who is more familiar with the Gigabyte board you are on with the 3600 in it to help you, they might have a trick to get boost to work properly, but essentially this is what happens.
Once you load all Cores and your T-Die Temp goes above 65-70c, Your All Core Boost Drops down to around 4Ghz. Is that what you are seeing? Because if so that is common with a bunch of 3900x and 3700x Owners. It seems 3800x owners are getting better boost speeds on average. Unless someone can tell you how to manipulate PB and PBO on your Board (there might be an older UEFI where it works better, 1.0.0.2 is where it worked best on ASUS boards) What I suggest, is at least Temporarily settings your Voltage to 1.3 to 1.35v on your vCore, and then seeing how far you can manually push an All Core. You will Most likely be able to get at least 4.25Ghz All Core at around 1.3v give or take 50mv, and then run Cinebench. I bet your Score will jump up to around the 3700 Mark or so. Again I don't have a 3600, so I am just halving my score to estimate where you should be landing, but I regularly hit around 7350 to 7400 on mine with a 4225Mhz All Core OC, so I am willing to bet you can get to around half that if you did the same.
I know it sucks boost is broken, but You may find that another UEFI works better for you, or you may find a Gigabyte board owner who knows how to manipulate PBO on their board willing to help you out. I recommend looking for a thread of people who own your board and post there as well.
Let me know if you get a better score with an All Core overclock though when you get a chance!
Just installed my 3600 on my X470 using Agesa 1002 and it boosts fine I think at Optimized Default, which I think is not as broken as 1003. HWMONITOR showed that mine boost to 4.2GHz (4.192 cos my BCLK is 99.8).
Tech Enthusiast
SWEET! Yeah judging from that I think if the OP doesn't want to All Core OC, and obviously it will be better for gaming workloads if you just went AUTO, then I think the best Recourse for him would be finding a UEFI that is using Agesa 1002 for his Board. They are definitely out there!
Great Post @rdr09 !
EDIT: Actually after looking at your HWmonitor more closely, if you aren't boosting above 4200Mhz for single core workloads, then it actually may be beneficial to see if you guys can All Core OC above 4200Mhz, You probably can.
Great Post @rdr09 !
It really helps to read experiences from others. When I learned that the latest Agesa is affecting boost, I stayed put.
@op, try Optimized Default and do not open Ryzen Master. BTW, I use Windows Balance Power Plan with Minimum Processor State set to 25%. My Core Clock and Voltage both downclock.
Discussion Starter #7
Well, **** !!!!
That did it !!! 3520 Cinebench 20 score.
I don't understand the logic. I never clicked load default optimized since I only adjusted the fan curve and loaded XMP profile. I assumed default optimized was ... well, default. The most simple things beat you. I was sure it had to be something stupid since no one complained about low cinebench scores on internet.
Thanks a lot man !
@oreonutz
All cores, mine doesn't seem to boost above 3900ish. I'll see now after is fixed.
Well, **** !!!!
Thanks a lot man !
@oreonutz
Cinebench Multi-threaded bench will use all cores and our chip will do 3900ish all core, which is normal. Single Thread bench should make one or two cores boost higher.
Enjoy your CPU. Isn't it Snappy?
Discussion Starter #9
Honestly, can't tell yet. This is more of a side upgrade. I had a 6700k which was doing fine.
I just wanted to give AMD a chance :) But since I got stuck on cinebench scores I never had time to test something else.
I'm gonna fire up some games and apps and see how it behaves.
So far, it pisses me off that despite having custom curve for fans in bios, it still rambles up and down, like is ignoring my settings. Anyway, my problem to work around now.
Thanks again !
What did your single core score on CB?
Thanks again !
Got a Noctua U12S with one fan and my temp never goes higher than 65c benching and gaming. Ambient is pretty low, tho. About 24c. All my fans are set to Silent mode except cpu fan set at PWM.
Got a 467 for Single all stock RAM at 2400 CL16.
454 with ryzen high perf
474 with balanced (windows)
Ram still at 2666
You beat my scores on both MT and ST. lol
Me think its my RAM. And its B-die! Have not have a chance to tune it yet. Got to play more cos it is back to school soon.
1 - 13 of 13 Posts
