Ryzen 5700g
559 Views 5 Replies 6 Participants Last post by  The_King
I have this set to over clock. But I'm getting spikes. Highest it's it so far is 10.5ghz. is this going to damage the CPU if I leave it set to over clock. Pic attached.
1 - 6 of 6 Posts
Not seen that before!
Dont worry, your CPU is not spiking to 10.5 Ghz
I am guessing its the software you are using (HWMonitor).
If you have not, try with HWInfo64 and check to see what the "effective clock" section shows with regards to frequency.
· Long Time Lurker
You either have the single most golden CPU ever made, or it’s a software reporting error. I know which I would put my bets on.
Wow, 10.5Mhz, But don't worry it won't take off.
We have a thread for 5700G in this forum too, if you want to compare it with others:
HWMonitor routinely reports my Ryzen 5800X hitting 5.5GHz. I doubt the chip is clocking that high, given that it isn't supposed to boost even to 5GHz. I'll go with HWMonitor being wonky.
I also have a 5700G in another system, though I don't monitor that one as much.
1 - 6 of 6 Posts
