1 - 2 of 2 Posts
Okay so I’ve run into a bit of a snag when it comes to finally overclocking my build, essentially I don’t know what I’m doing. I’ve tried to find help on YouTube and other inter webs but couldn’t seem to find anything helpful. I can’t seem to get a stable overclock over what the base is of 3.6hz without it being able to boot to windows. Here are my specs
Ryzen 7 1800x
H100i water cooler
ASROCK x370 Killer SLI
Nvidia GTX 1050ti (4gb)
2x8 Gb g.Skill TridentZ ram 3200mhz
Phanteks p400
3 120mm fans
Any help or insight would be greatly appreciated, even if it’s just getting me up past the base clock I’ll take any performance upgrades I can get.
Also can’t seem to figure out how to get the full 3200mhz from my ram, I know Ryzen is in its infancy and may not be ready yet but even 3000 MHz would suffice. Thanks!
What settings did you use? Hopefully you didn't forget to increase the voltages.
Also check the timings for the memory if they are too aggressive..
1 - 2 of 2 Posts
