181 - 200 of 258 Posts
Lets be clear about offsetting the voltage, all you are doing is raising the entire floor for every single core, pretty much defeating the purpose of doing negative offsets anyway. You're better off just finding the core(s) that arent playing nice and reducing the amount of negative voltage you are putting in the curve. Its a balancing act.
Also keep in mind that doing offset voltage will eat into the pbo budget (specifically edc) and you will get lower overall clocks. Doing it manually per core and finding the sweetspot for each one will result in better overall performance.
Its interesting that amd released the slide deck on this today and it seems what I stated before about there being a limit to the lowest possible offset rings true. For me, that was around negative 70 (the value entered in). Anything below that didnt do anything at all.
What I said last page also holds true. Tune your best 2 cores first to maximize their single core boost freq (just do runs of r20 single core and observe your core frequency in ryzen master to see what you actual effective clock speed is and hwinfo does not update fast/accurate enough to make it reliable in what the clocks are actually doing) and comnpare them with the score you get in r20). This will probably be around -20 - -5 for each of those two cores as pbo needs the voltage for the higher end (but does eat into your overall clock as there are per core currant/power limits).
Next, drop all of your other cores that are NOT the two best cores windows uses (can view this in ryzen master as well). I'm sure many people could drop all of these other cores to -20 - -70 without much issue. The reason being is that these cores are never running a heavy single core load. Those loads will always be shoved to your two best cores because...windows.
Just keep running r20 all core loads and turning down the remaining cores. For me, i hit the negative wall on all 14 remaining cores on my 5950x. I literally have 14/16 cores set to negative 160 because it lets me lol, not that it does anything different that what negative 70 does,
My two best are set to negative 10 and negative 20, which nets me a max effective freq of 5120 (5150 set) for single core and ~ 4.725ghz all core.
Results:
What are you settings in PBO?
Thanks. trying to compile a list of common settings that seem to be key to getting most out of this chips. CPU lotto helps also...lol
Here we go :)
My current 24/7 settings with fans on auto, 24 degrees ambient etc
[2021/01/14 04:22:38]
Ai Overclock Tuner [Manual]
BCLK Frequency [100.0000]
Memory Frequency [DDR4-3800MHz]
FCLK Frequency [1900MHz]
Core Performance Boost [Enabled]
CPU Core Ratio [Auto]
Core VID [Auto]
CCX0 Ratio [Auto]
CCX0 Ratio [Auto]
TPU [Keep Current Settings]
Performance Bias [Auto]
PBO Fmax Enhancer [Auto]
Precision Boost Overdrive [Manual]
PPT Limit [300]
TDC Limit [235]
EDC Limit [245]
Precision Boost Overdrive Scalar [Auto]
Max CPU Boost Clock Override [50]
Platform Thermal Throttle Limit [Auto]
DRAM CAS# Latency [14]
Trcdrd [15]
Trcdwr [8]
DRAM RAS# PRE Time [12]
DRAM RAS# ACT Time [24]
Trc [36]
TrrdS [4]
TrrdL [4]
Tfaw [16]
TwtrS [4]
TwtrL [10]
Twr [12]
Trcpage [Auto]
TrdrdScl [2]
TwrwrScl [2]
Trfc [252]
Trfc2 [187]
Trfc4 [115]
Tcwl [14]
Trtp [6]
Trdwr [9]
Twrrd [2]
TwrwrSc [1]
TwrwrSd [6]
TwrwrDd [6]
TrdrdSc [1]
TrdrdSd [5]
TrdrdDd [5]
Tcke [Auto]
ProcODT [40 ohm]
Cmd2T [1T]
Gear Down Mode [Enabled]
Power Down Enable [Disabled]
RttNom [RZQ/7]
RttWr [RZQ/3]
RttPark [RZQ/1]
MemAddrCmdSetup [Auto]
MemCsOdtSetup [Auto]
MemCkeSetup [Auto]
MemCadBusClkDrvStren [24.0 Ohm]
MemCadBusAddrCmdDrvStren [20.0 Ohm]
MemCadBusCsOdtDrvStren [24.0 Ohm]
MemCadBusCkeDrvStren [24.0 Ohm]
Mem Over Clock Fail Count [Auto]
Voltage Monitor [Die Sense]
CPU Load-line Calibration [Level 1]
CPU Current Capability [140%]
CPU VRM Switching Frequency [Manual]
Fixed CPU VRM Switching Frequency(KHz) [500]
CPU Power Duty Control [T.Probe]
CPU Power Phase Control [Extreme]
CPU Power Thermal Control [120]
VDDSOC Load-line Calibration [Level 3]
VDDSOC Switching Frequency [Auto]
VDDSOC Phase Control [Extreme]
DRAM Current Capability [130%]
DRAM Power Phase Control [Extreme]
DRAM Switching Frequency [Auto]
CPU Core Current Telemetry [Auto]
CPU SOC Current Telemetry [Auto]
Force OC Mode Disable [Disabled]
SB Clock Spread Spectrum [Auto]
VTTDDR Voltage [Auto]
VPP_MEM Voltage [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
VDDP Voltage [Auto]
1.8V Standby Voltage [Auto]
CPU 3.3v AUX [Auto]
1.2V SB Voltage [Auto]
DRAM R1 Tune [Auto]
DRAM R2 Tune [Auto]
DRAM R3 Tune [Auto]
DRAM R4 Tune [Auto]
PCIE Tune R1 [Auto]
PCIE Tune R2 [Auto]
PCIE Tune R3 [Auto]
PLL Tune R1 [Auto]
PLL reference voltage [Auto]
T Offset [Auto]
Sense MI Skew [Auto]
Sense MI Offset [Auto]
Promontory presence [Auto]
Clock Amplitude [Auto]
CPU Core Voltage [Offset mode]
  • Offset Mode Sign [+]
  • CPU Core Voltage Offset [0.02500]
CPU SOC Voltage [Manual]
- VDDSOC Voltage Override [1.10625]
DRAM Voltage [1.54500]
VDDG CCD Voltage Control [0.890]
VDDG IOD Voltage Control [Auto]
CLDO VDDP voltage [0.880]
1.00V SB Voltage [Auto]
1.8V PLL Voltage [Auto]
TPM Device Selection [Discrete TPM]
Erase fTPM NV for factory reset [Enabled]
PSS Support [Enabled]
PPC Adjustment [PState 0]
NX Mode [Enabled]
SVM Mode [Disabled]
SMT Mode [Auto]
Core Leveling Mode [Automatic mode]
CCD Control [Auto]
SATA Port Enable [Enabled]
SATA Mode [AHCI]
NVMe RAID mode [Disabled]
SMART Self Test [Enabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
HD Audio Controller [Enabled]
PCIEX16_1 Bandwidth Bifurcation configuration [Auto Mode]
PCIEX16_2 Bandwidth Bifurcation configuration [Auto Mode]
When system is in working state [All On]
Q-Code LED Function [POST Code Only]
When system is in sleep, hibernate or soft off states [All On]
Realtek 2.5G LAN Controller [Enabled]
Realtek PXE OPROM [Disabled]
Intel LAN Controller [Enabled]
Intel LAN OPROM [Disabled]
ASM1074 Controller [Enabled]
Wi-Fi 6 (802.11ax) Controller [Enabled]
Bluetooth Controller [Enabled]
USB power delivery in Soft Off state (S5) [Enabled]
PCIEX16_1 Mode [Auto]
PCIEX16_2 Mode [Auto]
PCIEX1 Mode [Auto]
PCIEX16_3 Mode [Auto]
M.2_1 Link Mode [Auto]
M.2_2 Link Mode [Auto]
SB Link Mode [Auto]
ErP Ready [Disabled]
Restore AC Power Loss [Power Off]
Power On By PCI-E [Disabled]
Power On By RTC [Disabled]
Above 4G Decoding [Enabled]
Re-Size BAR Support [Auto]
SR-IOV Support [Disabled]
Legacy USB Support [Enabled]
XHCI Hand-off [Enabled]
Corsair Voyager GTX 0 [Auto]
USB Device Enable [Enabled]
U32G2_2 [Enabled]
U32G2_3 [Enabled]
U32G2_4 [Enabled]
U32G1_10 [Enabled]
U32G1_11 [Enabled]
USB12 [Enabled]
USB13 [Enabled]
U32G2_7 [Enabled]
U32G2_8 [Enabled]
U32G2_C9 [Enabled]
Network Stack [Disabled]
Device [SATA6G_7: Samsung SSD 850 PRO 1TB]
CPU Temperature [Monitor]
CPU Package Temperature [Monitor]
MotherBoard Temperature [Monitor]
VRM Temperature [Monitor]
T_Sensor Temperature [Monitor]
Water In T Sensor Temperature [Monitor]
Water Out T Sensor Temperature [Monitor]
CPU Fan Speed [Monitor]
CPU Optional Fan Speed [Monitor]
Chassis Fan 1 Speed [Monitor]
Chassis Fan 2 Speed [Monitor]
Chassis Fan 3 Speed [Monitor]
High Amp Fan Speed [Monitor]
W_PUMP+ Speed [Monitor]
AIO PUMP Speed [Monitor]
PCH Fan Speed [Monitor]
Flow Rate [Monitor]
CPU Core Voltage [Monitor]
3.3V Voltage [Monitor]
5V Voltage [Monitor]
12V Voltage [Monitor]
CPU Fan Q-Fan Control [Auto]
CPU Fan Step Up [2.1 sec]
CPU Fan Step Down [0 sec]
CPU Fan Speed Low Limit [600 RPM]
CPU Fan Profile [Manual]
CPU Fan Upper Temperature [70]
CPU Fan Max. Duty Cycle (%) [100]
CPU Fan Middle Temperature [40]
CPU Fan Middle Duty Cycle (%) [60]
CPU Fan Lower Temperature [30]
CPU Fan Min Duty Cycle (%) [50]
Chassis Fan 1 Q-Fan Control [Auto]
Chassis Fan 1 Q-Fan Source [CPU]
Chassis Fan 1 Step Up [0 sec]
Chassis Fan 1 Step Down [0 sec]
Chassis Fan 1 Speed Low Limit [600 RPM]
Chassis Fan 1 Profile [Manual]
Chassis Fan 1 Upper Temperature [60]
Chassis Fan 1 Max. Duty Cycle (%) [100]
Chassis Fan 1 Middle Temperature [40]
Chassis Fan 1 Middle Duty Cycle (%) [90]
Chassis Fan 1 Lower Temperature [20]
Chassis Fan 1 Min Duty Cycle (%) [85]
Chassis Fan 2 Q-Fan Control [Auto]
Chassis Fan 2 Q-Fan Source [CPU]
Chassis Fan 2 Step Up [0 sec]
Chassis Fan 2 Step Down [0 sec]
Chassis Fan 2 Speed Low Limit [600 RPM]
Chassis Fan 2 Profile [Manual]
Chassis Fan 2 Upper Temperature [65]
Chassis Fan 2 Max. Duty Cycle (%) [100]
Chassis Fan 2 Middle Temperature [45]
Chassis Fan 2 Middle Duty Cycle (%) [60]
Chassis Fan 2 Lower Temperature [40]
Chassis Fan 2 Min Duty Cycle (%) [60]
Chassis Fan 3 Q-Fan Control [Auto]
Chassis Fan 3 Q-Fan Source [CPU]
Chassis Fan 3 Step Up [0 sec]
Chassis Fan 3 Step Down [0 sec]
Chassis Fan 3 Speed Low Limit [600 RPM]
Chassis Fan 3 Profile [Manual]
Chassis Fan 3 Upper Temperature [70]
Chassis Fan 3 Max. Duty Cycle (%) [100]
Chassis Fan 3 Middle Temperature [45]
Chassis Fan 3 Middle Duty Cycle (%) [100]
Chassis Fan 3 Lower Temperature [40]
Chassis Fan 3 Min Duty Cycle (%) [100]
High Amp Fan Q-Fan Control [Auto]
High Amp Fan Q-Fan Source [CPU]
High Amp Fan Step Up [0 sec]
High Amp Fan Step Down [0 sec]
High Amp Fan Speed Low Limit [600 RPM]
High Amp Fan Profile [Manual]
High Amp Fan Upper Temperature [70]
High Amp Fan Max. Duty Cycle (%) [100]
High Amp Fan Middle Temperature [60]
High Amp Fan Middle Duty Cycle (%) [70]
High Amp Fan Lower Temperature [30]
High Amp Fan Min Duty Cycle (%) [60]
Water Pump+ Q-Fan Control [Auto]
Water Pump+ Q-Fan Source [CPU]
Water Pump+ Upper Temperature [70]
Water Pump+ Max. Duty Cycle (%) [100]
Water Pump+ Middle Temperature [45]
Water Pump+ Middle Duty Cycle (%) [70]
Water Pump+ Lower Temperature [35]
Water Pump+ Min Duty Cycle (%) [60]
AIO Pump Q-Fan Control [Auto]
AIO Pump Q-Fan Source [CPU]
AIO Pump Upper Temperature [70]
AIO Pump Max. Duty Cycle (%) [100]
AIO Pump Middle Temperature [45]
AIO Pump Middle Duty Cycle (%) [80]
AIO Pump Lower Temperature [30]
AIO Pump Min Duty Cycle (%) [70]
Above 4GB MMIO Limit [39bit (512GB)]
Fast Boot [Enabled]
Next Boot after AC Power Loss [Fast Boot]
Boot Logo Display [Disabled]
Bootup NumLock State [On]
POST Report [5 sec]
Wait For 'F1' If Error [Enabled]
Option ROM Messages [Force BIOS]
Interrupt 19 Capture [Disabled]
Setup Mode [Advanced Mode]
Launch CSM [Disabled]
OS Type [Other OS]
AMI Native NVMe Driver Support [Enabled]
Flexkey [Reset]
Setup Animator [Disabled]
Load from Profile [6]
Profile Name [12.01.21 done]
Save to Profile [1]
DIMM Slot Number [DIMM_A1]
Bus Interface [PCIEX16_1]
Download & Install ARMOURY CRATE app [Enabled]
CPU Frequency [0]
CPU Voltage [0]
CCD Control [Auto]
Core control [Auto]
SMT Control [Auto]
Overclock [Enabled ]
Memory Clock Speed [Auto]
Tcl [Auto]
Trcdrd [Auto]
Trcdwr [Auto]
Trp [Auto]
Tras [Auto]
Trc Ctrl [Auto]
TrrdS [Auto]
TrrdL [Auto]
Tfaw Ctrl [Auto]
TwtrS [Auto]
TwtrL [Auto]
Twr Ctrl [Auto]
Trcpage Ctrl [Auto]
TrdrdScL Ctrl [Auto]
TwrwrScL Ctrl [Auto]
Trfc Ctrl [Auto]
Trfc2 Ctrl [Auto]
Trfc4 Ctrl [Auto]
Tcwl [Auto]
Trtp [Auto]
Tcke [Auto]
Trdwr [Auto]
Twrrd [Auto]
TwrwrSc [Auto]
TwrwrSd [Auto]
TwrwrDd [Auto]
TrdrdSc [Auto]
TrdrdSd [Auto]
TrdrdDd [Auto]
ProcODT [Auto]
Power Down Enable [Auto]
Cmd2T [Auto]
Gear Down Mode [Auto]
CAD Bus Timing User Controls [Auto]
CAD Bus Drive Strength User Controls [Auto]
Data Bus Configuration User Controls [Auto]
Infinity Fabric Frequency and Dividers [Auto]
ECO Mode [Disable]
Precision Boost Overdrive [Advanced]
PBO Limits [Motherboard]
Curve Optimizer [Per Core]
Core 0 Curve Optimizer Sign [Negative]
Core 0 Curve Optimizer Magnitude [30]
Core 1 Curve Optimizer Sign [Negative]
Core 1 Curve Optimizer Magnitude [30]
Core 2 Curve Optimizer Sign [Negative]
Core 2 Curve Optimizer Magnitude [30]
Core 3 Curve Optimizer Sign [Negative]
Core 3 Curve Optimizer Magnitude [30]
Core 4 Curve Optimizer Sign [Negative]
Core 4 Curve Optimizer Magnitude [30]
Core 5 Curve Optimizer Sign [Negative]
Core 5 Curve Optimizer Magnitude [30]
Core 6 Curve Optimizer Sign [Negative]
Core 6 Curve Optimizer Magnitude [30]
Core 7 Curve Optimizer Sign [Negative]
Core 7 Curve Optimizer Magnitude [30]
Core 8 Curve Optimizer Sign [Negative]
Core 8 Curve Optimizer Magnitude [30]
Core 9 Curve Optimizer Sign [Negative]
Core 9 Curve Optimizer Magnitude [30]
Core 10 Curve Optimizer Sign [Negative]
Core 10 Curve Optimizer Magnitude [30]
Core 11 Curve Optimizer Sign [Negative]
Core 11 Curve Optimizer Magnitude [30]
Core 12 Curve Optimizer Sign [Negative]
Core 12 Curve Optimizer Magnitude [30]
Core 13 Curve Optimizer Sign [Negative]
Core 13 Curve Optimizer Magnitude [30]
Core 14 Curve Optimizer Sign [Negative]
Core 14 Curve Optimizer Magnitude [30]
Core 15 Curve Optimizer Sign [Negative]
Core 15 Curve Optimizer Magnitude [30]
Max CPU Boost Clock Override [0MHz]
LN2 Mode [Auto]
SoC/Uncore OC Mode [Disabled]
VDDP Voltage Control [Auto]
VDDG Voltage Control [Auto]
NUMA nodes per socket [Auto]
Custom Pstate0 [Auto]
L1 Stream HW Prefetcher [Auto]
L2 Stream HW Prefetcher [Auto]
Core Watchdog Timer Enable [Auto]
SMEE [Auto]
Core Performance Boost [Auto]
Global C-state Control [Disabled]
Power Supply Idle Control [Typical Current Idle]
SEV ASID Count [Auto]
SEV-ES ASID Space Limit Control [Auto]
Streaming Stores Control [Auto]
Local APIC Mode [Auto]
ACPI _CST C1 Declaration [Auto]
MCA error thresh enable [Auto]
PPIN Opt-in [Auto]
Fast Short REP MOVSB [Enabled]
Enhanced REP MOVSB/STOSB [Enabled]
RdRand Speedup Disable [Enabled]
IBS hardware workaround [Auto]
DRAM scrub time [Auto]
Poison scrubber control [Auto]
Redirect scrubber control [Auto]
Redirect scrubber limit [Auto]
Memory interleaving [Auto]
Memory interleaving size [Auto]
1TB remap [Auto]
DRAM map inversion [Auto]
ACPI SRAT L3 Cache As NUMA Domain [Auto]
ACPI SLIT Distance Control [Auto]
ACPI SLIT remote relative distance [Auto]
GMI encryption control [Auto]
xGMI encryption control [Auto]
CAKE CRC perf bounds Control [Auto]
4-link xGMI max speed [Auto]
3-link xGMI max speed [Auto]
xGMI TXEQ Mode [Auto]
PcsCG control [Auto]
Disable DF to external downstream IP SyncFloodPropagation [Auto]
Disable DF sync flood propagation [Auto]
CC6 memory region encryption [Auto]
Memory Clear [Auto]
Overclock [Enabled]
Tcl [Auto]
Trcdrd [Auto]
Trcdwr [Auto]
Trp [Auto]
Tras [Auto]
Trc Ctrl [Auto]
TrrdS [Auto]
TrrdL [Auto]
Tfaw Ctrl [Auto]
TwtrS [Auto]
TwtrL [Auto]
Twr Ctrl [Auto]
Trcpage Ctrl [Auto]
Trfc Ctrl [Auto]
Trfc2 Ctrl [Auto]
Trfc4 Ctrl [Auto]
Tcwl [Auto]
Trtp [Auto]
Tcke [Auto]
Trdwr [Auto]
Twrrd [Auto]
TwrwrSc [Auto]
TwrwrSd [Auto]
TwrwrDd [Auto]
TrdrdSc [Auto]
TrdrdSd [Auto]
TrdrdDd [Auto]
ProcODT [Auto]
Disable Burst/Postponed Refresh [Auto]
DRAM Maximum Activate Count [Auto]
Cmd2T [Auto]
Data Poisoning [Auto]
DRAM Post Package Repair [Default]
RCD Parity [Auto]
DRAM Address Command Parity Retry [Auto]
Write CRC Enable [Auto]
DRAM Write CRC Enable and Retry Limit [Auto]
Disable Memory Error Injection [True]
DRAM ECC Symbol Size [Auto]
DRAM ECC Enable [Auto]
DRAM UECC Retry [Auto]
TSME [Auto]
Data Scramble [Auto]
DFE Read Training [Auto]
FFE Write Training [Auto]
PMU Pattern Bits Control [Auto]
MR6VrefDQ Control [Auto]
CPU Vref Training Seed Control [Auto]
Chipselect Interleaving [Auto]
BankGroupSwap [Auto]
BankGroupSwapAlt [Auto]
Address Hash Bank [Auto]
Address Hash CS [Auto]
Address Hash Rm [Auto]
SPD Read Optimization [Enabled]
MBIST Enable [Disabled]
Pattern Select [PRBS]
Pattern Length [6]
Aggressor Channel [1 Aggressor Channel]
Aggressor Static Lane Control [Disabled]
Target Static Lane Control [Disabled]
Worst Case Margin Granularity [Per Chip Select]
Read Voltage Sweep Step Size [1]
Read Timing Sweep Step Size [1]
Write Voltage Sweep Step Size [1]
Write Timing Sweep Step Size [1]
IOMMU [Auto]
Precision Boost Overdrive [Auto]
FCLK Frequency [Auto]
SOC OVERCLOCK VID [0]
UCLK DIV1 MODE [Auto]
SoC/Uncore OC Mode [Auto]
LN2 Mode [Auto]
ACS Enable [Auto]
PCIe ARI Support [Auto]
PCIe ARI Enumeration [Auto]
PCIe Ten Bit Tag Support [Auto]
cTDP Control [Auto]
EfficiencyModeEn [Auto]
Package Power Limit Control [Auto]
APBDIS [Auto]
DF Cstates [Auto]
CPPC [Auto]
CPPC Preferred Cores [Auto]
NBIO DPM Control [Auto]
Early Link Speed [Auto]
Presence Detect Select mode [Auto]
Preferred IO [Auto]
CV test [Auto]
Loopback Mode [Auto]
Data Link Feature Exchange [Disabled]
Scores in benchmarks with current settings:
2474066
And some heavyer y-cruncher benchmarks, do note the 295 watt usage.. Good cooling is required :)
2474067
Here we go :)
Your results look pretty great. I've tried various curves but the most negative I can go all cores is 22 anything higher the system would reset when just opening benchmate. Not sure if I am missing something. I know the 5950X I have is not too bad. Under dry ice I was able to do 5.25ghz using 1.525vcore as for some reason I could not go higher on the vcore.
Hi domdtxdissar,
I followed your settings and finally, for two days. No more crashing! Thank you so much!!! My only problem now is my temp. During cinebench, it reached 90 degrees and when I do something on my computer like browsing, downloading games and installing other stuffs. My temp plays from 50 to 65. Are these normal?
Here we go :)
Did u check the max voltages? domdtxdissar screens show > 1,5v which is quite high and require very good cooling
Ohh sorry. It is my first time using a bios and most especially using AMD. I have been an intel boy since 1995. lol Can you please recommend how to lower the temp please? I'm using kraken z73 and uni fan sl120 as my coolers.
Welcome on board ;)
Skickat från min SM-G973F via Tapatalk
Here we go :)
Tried your setting couldnt get same or close results. Clocks were way low. Dont know? Maybe 2 CCD chips power needs make difference. I was able to tweak my settings... My two best cores don't like anything past -5 on curve and was only stable to 5050mhz in CB23 at that point effective clocks didn't return as high, ex.(set 5075mhz but eff. was 5020mhz)or would just crash CB23 and give error. Binning and high base boost definitely help 5950X chips reach alittle higher. I was able to get it to this point 24/7 stable.
Temps are good. running custom loop with 480/360 rads. Hopefully newer BIOS for my X470 board will get be better clocks and tighter timings on memory.
Pre-order, but B&H Photo are pretty decent, and delays not too bad.
STILL haven't gotten my 5950x and but I'll quite likely have it by the time I get the board. Guy that ordered from the same store as me the same day got his four days ago. :)
Running a 3950x currently.
2474280
Has anyone noticed that dropping EDC,TDC,PPT and playing with LLC drops L3 cache performance? I noticed that my clocks were high 5050mhz single and 4750mhz multi but L3 scores in Aida64 were tanked for R/W/C. As soon as I raised EDC noticed they went up. Ex:
R20 Multi Core
EDC 110A 4725-4750mhz- score 6150-6200pts Aida-R-175GBs/W-310GBs/C-180GBs
EDC 135A 4625-4650mhz- score 6225-6320pts Aida-R-210GBs/W-335GBs/C-354GBs
One last hurrah for bios 3003 before i update to a bios with AMD AM4 AGESA V2 PI 1.2.0.0 and support for Nvidia smart access memory.
Cold air benching with EK custom waterloop+TechN Zen3 waterblock :)
Curve optimizer = -30 allcore
Stable in everything i throw at it, and no WHEA errors.
2475344
Cinebench r23 multithread = 32229 points
Cinebench r23 singlethread = 1729 points
Cinebench r20 multithread = 12441 points
Cinebench r20 singlethread = 674 points
Cinebench r15 multithread = 5404 points
Cinebench r15 multithread = 288 points
CPU-Z validator @ AMD Ryzen 9 5950X @ 4798.88 MHz - CPU-Z VALIDATOR
Some Asus realbench + Passmark performancetest numbers @ PassMark Software - Display Baseline ID# 1359214 (This machine is ranked #36 out of 156355 results globally)
2475345
Geekbench 4 @ ASUS System Product Name - Geekbench Browser
Singlethread = 8215 points
Multithread = 74733 points
Geekbench5 @ ASUS System Product Name - Geekbench Browser
Singlethread = 1844 points
Multithread = 20054 points
Some heavy IBT high+very high and Y-Cruncher numbers:
2475346
Did also run a full sweep of all 3dmarks, but i will post that in one other thread :)
[2021/01/20 16:26:21]
Core VID [Auto]
CCX0 Ratio [Auto]
CCX0 Ratio [Auto]
PPT Limit [300]
TDC Limit [235]
EDC Limit [245]
Precision Boost Overdrive Scalar [Manual]
Customized Precision Boost Overdrive Scalar [4X]
Trcdrd [15]
Trcdwr [8]
Trc [36]
TrrdS [4]
TrrdL [4]
Tfaw [16]
TwtrS [4]
TwtrL [10]
Twr [12]
Trcpage [Auto]
TrdrdScl [2]
TwrwrScl [2]
Trfc [252]
Trfc2 [187]
Trfc4 [115]
Tcwl [14]
Trtp [6]
Trdwr [9]
Twrrd [2]
TwrwrSc [1]
TwrwrSd [6]
TwrwrDd [6]
TrdrdSc [1]
TrdrdSd [5]
TrdrdDd [5]
Tcke [Auto]
ProcODT [40 ohm]
Cmd2T [1T]
RttNom [RZQ/7]
RttWr [RZQ/3]
RttPark [RZQ/1]
MemCkeSetup [Auto]
CPU Load-line Calibration [Level 3]
VDDP Voltage [Auto]
CPU 3.3v AUX [Auto]
DRAM R1 Tune [Auto]
DRAM R2 Tune [Auto]
DRAM R3 Tune [Auto]
DRAM R4 Tune [Auto]
PCIE Tune R1 [Auto]
PCIE Tune R2 [Auto]
PCIE Tune R3 [Auto]
PLL Tune R1 [Auto]
T Offset [Auto]
  • CPU Core Voltage Offset [0.01250]
- VDDSOC Voltage Override [1.11875]
NX Mode [Enabled]
SVM Mode [Disabled]
SMT Mode [Auto]
CCD Control [Auto]
SATA Mode [AHCI]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Wi-Fi 6 (802.11ax) Controller [Disabled]
PCIEX1 Mode [Auto]
SB Link Mode [Auto]
U32G2_2 [Enabled]
U32G2_3 [Enabled]
U32G2_4 [Enabled]
U32G1_10 [Enabled]
U32G1_11 [Enabled]
USB12 [Enabled]
USB13 [Enabled]
U32G2_7 [Enabled]
U32G2_8 [Enabled]
U32G2_C9 [Enabled]
Flow Rate [Monitor]
CPU Fan Middle Temperature [50]
CPU Fan Middle Duty Cycle (%) [50]
CPU Fan Min Duty Cycle (%) [40]
Chassis Fan 1 Upper Temperature [70]
Chassis Fan 1 Middle Temperature [50]
Chassis Fan 1 Middle Duty Cycle (%) [65]
Chassis Fan 1 Min Duty Cycle (%) [60]
High Amp Fan Middle Temperature [45]
Water Pump+ Middle Temperature [50]
Water Pump+ Middle Duty Cycle (%) [65]
Water Pump+ Lower Temperature [30]
AIO Pump Middle Temperature [50]
AIO Pump Middle Duty Cycle (%) [65]
AIO Pump Min Duty Cycle (%) [60]
Fast Boot [Enabled]
POST Report [5 sec]
OS Type [Other OS]
Flexkey [Reset]
Load from Profile [5]
Profile Name [20.01 minus 30]
Save to Profile [5]
CPU Frequency [0]
CPU Voltage [0]
CCD Control [Auto]
Core control [Auto]
SMT Control [Auto]
Tcl [Auto]
Trcdrd [Auto]
Trcdwr [Auto]
Trp [Auto]
Tras [Auto]
Trc Ctrl [Auto]
TrrdS [Auto]
TrrdL [Auto]
Tfaw Ctrl [Auto]
TwtrS [Auto]
TwtrL [Auto]
Twr Ctrl [Auto]
Trcpage Ctrl [Auto]
Trfc Ctrl [Auto]
Trfc2 Ctrl [Auto]
Trfc4 Ctrl [Auto]
Tcwl [Auto]
Trtp [Auto]
Tcke [Auto]
Trdwr [Auto]
Twrrd [Auto]
TwrwrSc [Auto]
TwrwrSd [Auto]
TwrwrDd [Auto]
TrdrdSc [Auto]
TrdrdSd [Auto]
TrdrdDd [Auto]
ProcODT [Auto]
Cmd2T [Auto]
ECO Mode [Disable]
LN2 Mode [Auto]
SMEE [Auto]
PPIN Opt-in [Auto]
1TB remap [Auto]
Memory Clear [Auto]
Overclock [Enabled]
Tcl [Auto]
Trcdrd [Auto]
Trcdwr [Auto]
Trp [Auto]
Tras [Auto]
Trc Ctrl [Auto]
TrrdS [Auto]
TrrdL [Auto]
Tfaw Ctrl [Auto]
TwtrS [Auto]
TwtrL [Auto]
Twr Ctrl [Auto]
Trcpage Ctrl [Auto]
Trfc Ctrl [Auto]
Trfc2 Ctrl [Auto]
Trfc4 Ctrl [Auto]
Tcwl [Auto]
Trtp [Auto]
Tcke [Auto]
Trdwr [Auto]
Twrrd [Auto]
TwrwrSc [Auto]
TwrwrSd [Auto]
TwrwrDd [Auto]
TrdrdSc [Auto]
TrdrdSd [Auto]
TrdrdDd [Auto]
ProcODT [Auto]
Cmd2T [Auto]
RCD Parity [Auto]
TSME [Auto]
Pattern Length [6]
IOMMU [Auto]
LN2 Mode [Auto]
ACS Enable [Auto]
cTDP Control [Auto]
APBDIS [Auto]
DF Cstates [Auto]
CPPC [Auto]
Preferred IO [Auto]
CV test [Auto]
I updated to the AMD AM4 AGESA V2 PI 1.2.0.0 Beta BIOS(5833) for my ROG Strix x470 board but it seemed to lower scores by 2-3% and PBO for my 5800X was locked to 5025mhz boost. Where before I could clock as high as CPU would let me(5100mhz) under old BIOS(5809). Went back to old BIOS for now till they post non beta version.
Best "stable" speed I can push the 5800X to:
Unfortunately AGESA firmware and I'm sure microcoding limit the top end speed each CPU can get to. As you can see in chart 5950X get to 5025/5050mhz with PBO enabled then you have another 200mhz worth of boost to push it more, if stable depending on your CPU quality. I've seen the following clocks stable w/o clock stretching per chip:
5950X- 5100-5150mhz
5900X- no info
5800X- 5025-5100mhz
5600X- 4900-4950mhz
Listed
1T
Firm
ware
1T*
Data
1T
Listed
Base
Data
nT
TDP
(W)
Data
(W)
nT
W/core
Ryzen 9 5950X490050255050340037751051426.12
Ryzen 9 5900X480049254950370041501051427.85
Ryzen 7 5800X4700482548253800445010514014.55
Ryzen 5 5600X46004625465037004450657610.20
*Listed 1T: The official number on the box
*Firmware 1T: 'Maximum Frequency' as listed in CPU registers in AGESA 1100
