1 - 20 of 39 Posts
So, seems we are a rare breed.
Hopefully not so rare that this thread does not move past a few pages
:p
Will post some benchmarks a little later on as I have almost dialled my rig in
Just a stability/settings screenshot for the time being
BCLK @107.5625
EDC @3
Power Plan: Windows Balanced
OS State: Workstation, AV running etc etc
:D
CB20 - 4045 | 533
CB15 - 1782 | 217
CPU-Z - 4502 | 550.4
GB5 - 8473 | 1376
GB4 - 31869 | 6319
Linpack - 300 GFlops
Reactions: Veii
Too many Ryzen MBs don't have BCLK adjustable. I had to trick mine just to stay at 100 otherwise it was fluctuating between 99.6 and 99.9.
I don't have scores to post, but just wanted to say that with the system in my sig I can only get it to 101.2, maybe 101.4, but just leave it at 100. When I had a 1700x cpu, everything else the same, I had it up to 106.something. And it actually made my 970 m.2 scores improve as well. Not by much, but you could definitely see it, beyond normal deviation.
Discussion Starter #4
Failing to understand what this has to do with me asking peeps who use BCLK to post their results ....
Of course some motherboards dont have such adjustments.
Dont know how you "trick it" usually you just disable "spread spectrum" if that option is available to you and BCLK will be at 100 mhz.
I had to limit PCIe to Gen2 and after that I could push BCLK upwards and onwards.
As I am using a 3600 its essentially super charged my CPU, get the best of both Worlds when combined with the EDC bug
does limiting the pcie to gen2 affect your m.2 scores?
Discussion Starter #6
How did you "trick" the BIOS? Would this work also on an ASUS X470-PLUS Gaming?
Discussion Starter #9
I can get 108 BCLK on my board. I have to go to PCIE2 over 105 on the BLCK. Don't make fun of my A320 motherboard! LOL
Excellent!
Thanks for posting
AMD OVERLOCKER
:p
BCLK @107.5625
EDC @3
:D
CB20 - 4045 | 533
CB15 - 1782 | 217
GB5 - 8473 | 1376
GB4 - 31869 | 6319
Which Mobo is this and what ssd/m2 do u have active while using this BCLK?
BTW your CB15 is low if you run all cores at 4.500.
Mine is 1806 at 4.441mhz.
Discussion Starter #12
:p
everything is in my sig
But I am not running all core at 4.5 Ghz, I am using BCLK with EDC bug and the score is fantastic for an everyday workstation rig, this is not a benching rig....
So my clocks auto adjust according to what is being demanded of it.
So if a "light" application needs to pull + 4.6 Ghz from a core it can do
I would like to increase the BCLK, but if i set it to, lets say, 101 than de cpu wont boost anymore. It just stay on 3600 MHz. I have an Asus PRIME X570-PRO with the latest bios and a Ryzen 5 3600.
I can't understand why he do that :(
Did you try disable/enable "C-States" & "Core Performance Boost"? Don't leave it on auto! I had to disable those setting for it to work or I get the same bug as you.
AMD OVERLOCKER
:p
It sounds good then!
But I can't see your signature, because I am entering from Tapatalk. Or else I wouldn't ask you for details.
Sent from my ONEPLUS A6003 using Tapatalk
Discussion Starter #16
Here you go
SeaSonic X750 Gold 750W
MSI X370 XPOWER Gaming Titanium | Ryzen 5 3600 2016SUS BCLK @107.5625 | EDC @3
Viper Steel Series PVS416G413C9K @ 3800/1900 mhz | 1.536v | 14-15-14-12-26-40-240-16-1T
Asus GTX 780 DCII OC @ 1332/3522 mhz | 1.3v | Samsung 960 EVO 500GB
EK-FB MSI X370 XPower RGB Monoblock 1/2" ID | Swiftech D5 MCP655 | EK-XRES 100
Alphacool NexXxoS UT60 280 | 4 x Scythe GT AP-15 @ 5v
Thermochill PA120.3 | 1 x NF-A12x15 | 2 x ML120 | PWM
If you want me to run any hard disk benchies let me know and i will run them tomorrow
AMD OVERLOCKER
Here you go
I don't see anywhere your discs.
Discussion Starter #18
Its right there in the sig, next to "Asus GTX 780 DCII OC @ 1332/3522 mhz | 1.3v |"
Mmm, that's a good one. I'll give it a try. Thanks
Here is my bclk overclock with Ryzen 3300X at 103.5 FSB. I use every day with these settings, have found it rock stable. SSD also performs awesome, seems bclk has some good effect for everything.
1 - 20 of 39 Posts
