41 - 60 of 1735 Posts
Version 3401 is out for asus boards, any progress regarding the modded versions? CBS and spread spectrum unlocked are really useful but in 3203 it mess up the ram OC.
AMD overclocker/developer
Discussion Starter #43
Originally Posted by blackangel12
/img/forum/go_quote.gif​
there will be modified versions, but on aresa 1.0.7.2b. Previous versions have tremendous instability, I worry about users
Gigabyte AX370 Gaming K7 F10 BIOS with unlocked AMD CBS (pstates are working!) and PBS.
AX370GK7.F10.MOD.zip
great
great
I forgot about that, after reading so many reports about it lol, my system has those "bugged" bios and i have to say that for me works great, but i guess with all hardware configuration and settings that wasn't true for majority of the users, so its worth the extra wait time just to be sure. Keep the good work
Thanks for your post,
It says
"Set a checkmark to "Create a DOS startup disk" and search for the "usbdos" folder contained in the download"
I downloaded the file that I needed (the bios) but there is no HP Tool, AFUDOS Tool or Usbdos files
Is there a separate link for the other files cause I don't see it?
Thanks
Discussion Starter #46
It says
Thanks
https://puissanceled.com/vrac/Bios_modding/EN.html
here all the links and at the end of the page instruction
Anyone else test this modded bios? Some charrity soul that mod this bios with spread spectrum?? Its already off on Giga but should be nice to lower voltage a little
Hi there, I did inspect your BIOS with AMIBCP and I did not find any spread spectrum, sorry.
I saw that too already as i proceed to test it myselft on my back up bios
Its funny because the mobos that have it disabled we want to enabled...and the mobos that came enabled they want it disabled
Well, at least p-states its working fine with down clock and downvolt correctly.
i wonder why giga disabled p-states
There's "Int. Clk Differential Spread" option available in "SB SATA DEBUG Configuration" form, is that what you are looking for?
Also there's another option "SB Clock Spread Spectrum" in "SB MISC DEBUG Configuration" form.
Both are hidden by default.
[CODE]0x2520B                              One Of: Int. Clk Differential Spread, VarStoreInfo (VarOffset/VarName): 0x87, VarStore: 0x1, QuestionId: 0x1B7, Size: 1, Min: 0x0, Max 0xFF, Step: 0x0 {05 91 D4 05 D5 05 B7 01 01 00 87 00 10 10 00 FF 00}
0x2521C                                         One Of Option: Disabled, Value (8 bit): 0x0 {09 07 04 00 00 00 00}
0x25223                                         One Of Option: Enabled, Value (8 bit): 0x1 {09 07 03 00 00 00 01}
0x2522A                                         One Of Option: Auto, Value (8 bit): 0xFF (default) {09 07 05 00 30 00 FF}
0x25231                                 End One Of {29 02}
[/CODE]
[CODE]0x25984                      One Of: SB Clock Spread Spectrum, VarStoreInfo (VarOffset/VarName): 0xB4, VarStore: 0x1, QuestionId: 0x1E3, Size: 1, Min: 0x0, Max 0xFF, Step: 0x0 {05 91 50 05 51 05 E3 01 01 00 B4 00 10 10 00 FF 00}
0x25995                                 One Of Option: Disabled, Value (8 bit): 0x0 {09 07 04 00 00 00 00}
0x2599C                                 One Of Option: Enabled, Value (8 bit): 0x1 {09 07 03 00 00 00 01}
0x259A3                                 One Of Option: Auto, Value (8 bit): 0xFF (default) {09 07 05 00 30 00 FF}
0x259AA                         End One Of {29 02}
[/CODE]
[/CODE]
[/CODE]
The second one is the one
Is there a way to unhidden it?
So, i know now (in the bad way) why giga disabled p-states. If you set a bad settings on ram or cpu the MOBO dont try to reset bios it just soft bricked forever, wiping the battery and reset cmos without power cable didnt work for me, the only way to recover my secondary bios was to boot with primary bios and then flashing again backup bios from there.
So, if you will use p-states with this modded bios be sure you input your safe settings.
Hey @1usmus, just wondering, could you make a modded 1001 with HPET and Spread Spectrum disabled for the B350-F strix?
I'm having trouble with the 3203 bios,
Discussion Starter #55
when it comes out AGESA 1.0.0.0a pinnaclepi I will release the modifications
Top mate thx!
Gesendet von meinem DUK-L09 mit Tapatalk
Gigabyte unlocked amd_cbs & amd_pbc AGESA 1.0.0.6b
Flashing Asus motherboard:
Because the digital signature is no longer present, it is no longer possible to flash the bios via the internal EZ Flash function.
We have to switch to the AMI own flashtool "AFUDOS".
Create a DOS Startup Disk
Plug in a USB flash drive, install "HP USB Boot Utility" and then open the "HP USB DiskStarage Format Tool" program.
Set a checkmark to "Create a DOS startup disk" and search for the "usbdos" folder contained in the download.
Click "Start" to start the formatting process.
Now copy the program "AFUDOS" as well as the bios on your USB stick.
Restart the PC, load and save in the bios the default settings.
Boats from the USB stick.
Type the following command: "afudos xxxx.rom / GAN" (replace xxxx with the name you gave earlier).
The read, delete, write, and verify process now starts automatically.
_
I downloaded the mod mate for CH6 but i can't find a USBDOS file in it. Can you provide this please?
with regards
BUFU
Tetrapyloctomist
I own two ZEN chips.. and i haven't the slightest about CBS, lol
What is it? :)
As usual, Google's of no help, unless it's my age. Help wanted
