Hey Veii, thx for your quick and informative reply!
I am a bit confused because you compared the A320M-C Rev 2.0 with the Prime A320-A. Is that board identical to the A320M-C?
But that comparison looks awesome! Where did you get that from?
All the best
Jan
Thought issue, thought they are identical as i compared the boards not the name
New revision shouldn't cause issues, at worse something was HW side fixed that caused issues
Sadly old revision is not to be found ~ soo i guess it's just identical
(except a patch on X port or bigger ROM, as it usually was the case // fix on usb-c and so on)
From this docs:
Here is AMIBCP v5.02.00
34 [PASS: OCN2022]
It does sign edited bioses to some extend
(need to test vendor locks)
But still needs a split in half to be edited
I suggest on generally any Bios, to check wherever SETUP_VAR locks exist
And for 1206A/B onwards, to force enable Vermeer(-X) overclocking support
Easier non bios-modding ways, to follow
But as always,
I am not the owner of the product, and sharing is done for general education purposes to bring development further
Credits do not belong to me for version 0034, but it is a re'upload to support international userbase
The same goes for bios mods, any user-experiment you try falls under own blame & own assurance
