1 - 9 of 9 Posts
Since a ton of people have complained about voltages, heat, etc. I've decided to publish the Windows power plan I use on my 3900X. This plan causes the CPU to downclock to 2.2 GHz and 0.95V or even lower (on my system it can sometimes hit a low of 0.2V). Doing light tasks like browsing the internet, etc. won't cause the spike in clocks and resulting increase in power/temperatures. The fans on my machine actually stay at very low speeds the majority of the time. There also does not appear to be any performance decrease.
I am creating this topic for discussion. The download link on the page will be added shortly after I create this thread, I need to create this topic first so I can include the link to it in the readme. If you decide to share this link, please share the link to the page rather than the download so that users can download the latest updates if the plan is updated. Also I may move the files around at some point which would result in an http 404.
If the link below does not work for you, please try CTRL + F5 in your browser. DNS is still refreshing since this domain was originally managed elsewhere, so it may take up to 48 hours. If accessibility continues to be an issue please post here.
Please read the readme for installation instructions, I attempted to post them here, but the post was blocked by some type of anti-spam software.
Link: http://hwgeeks.com/ryzen_power_saver
EDIT: The download link is live.
Discussion Starter #2
To give you an idea of how well this works, HWINFO has been open for 27 minutes. The average CPU Temp is 37C. Average SVI2 TFN voltage is 0.96V (CPU VID was 0.2V for minimum). Average clock speeds are 2.3-2.4 GHz (average effective clock is 40.8 MHz), Average fan speed is 692 RPM.
Activities have included:
1) Browsing the internet in multiple tabs.
2) Watching a Youtube video.
3) Zipping up files
4) Uploading those files via FileZilla
The MAX clockspeed while performing these activities was 2,400 MHz. I also started steam, it jumped to 3.2 GHz for about 2 seconds after Steam started up, then dropped back to 2.2 GHz. Gaming I averaged 4.25-4.45 GHz with peaks of around 4.6 GHz.
3) Zipping up files
May I ask an obvious question? (Perhaps I missed it) ------ As you know, downloading "files" from strangers on the internet is really not a good idea. Especially when it comes to some magic formula.
HOWEVER** - my gut is telling me you are sincere in your efforts to help / not to hurt. With that said, the question: Why not share your settings and let us match them and see what's up?
Discussion Starter #4
Given that it's just a generic power config file, there isn't much danger in installing it. It's not executable, however I will try and dump the settings tomorrow. I've been tweaking things locally (especially the boost thresholds), so I'll have to export my current one and import the one I have posted, then I will share it.
i was curious to see what are the setting that get changed, this is done in a brand new install of windows 10 2004 in a vmware (isolated guest)
(my main OS is using this mod: https://www.reddit.com/r/Amd/comments/eng1y8/ryzen_3700x_high_iddle_temps_and_fan_speed/ )
this one vs (default windows high performance)
Subgroup GUID: 19cbb8fa-5279-450e-9fac-8a3d5fedd0c1 (Wireless Adapter Settings)
Power Setting GUID: 12bbebe6-58d6-4636-95bb-3217ef867c1a (Power Saving Mode)
Possible Setting Index: 000
Possible Setting Friendly Name: Maximum Performance
Possible Setting Index: 001
Possible Setting Friendly Name: Low Power Saving
Possible Setting Index: 002
Possible Setting Friendly Name: Medium Power Saving
Possible Setting Index: 003
Possible Setting Friendly Name: Maximum Power Saving
Current AC Power Setting Index: 0x00000003 (default: 0x00000000)
Current DC Power Setting Index: 0x00000000
Subgroup GUID: 501a4d13-42af-4429-9fd1-a8218c268e20 (PCI Express)
GUID Alias: SUB_PCIEXPRESS
Power Setting GUID: ee12f906-d277-404b-b6da-e5fa1a576df5 (Link State Power Management)
GUID Alias: ASPM
Possible Setting Friendly Name: Off
Possible Setting Friendly Name: Moderate power savings
Possible Setting Friendly Name: Maximum power savings
Current AC Power Setting Index: 0x00000002 (default: 0x00000000)
Subgroup GUID: 54533251-82be-4824-96c1-47b60b740d00 (Processor power management)
GUID Alias: SUB_PROCESSOR
Power Setting GUID: 06cadf0e-64ed-448a-8927-ce7bf90eb35d (Processor performance increase threshold)
GUID Alias: PERFINCTHRESHOLD
Minimum Possible Setting: 0x00000000
Maximum Possible Setting: 0x00000064
Possible Settings increment: 0x00000001
Possible Settings units: %
Current AC Power Setting Index: 0x00000055 (default: 0x0000001e)
Current DC Power Setting Index: 0x0000001e
Power Setting GUID: 06cadf0e-64ed-448a-8927-ce7bf90eb35e (Processor performance increase threshold for Processor Power Efficiency Class 1)
GUID Alias: PERFINCTHRESHOLD1
Current AC Power Setting Index: 0x0000005f (default: 0x0000003c)
Current DC Power Setting Index: 0x0000005a
Power Setting GUID: 465e1f50-b610-473a-ab58-00d1077dc418 (Processor performance increase policy)
GUID Alias: PERFINCPOL
Possible Setting Friendly Name: Ideal
Possible Setting Friendly Name: Single
Possible Setting Friendly Name: Rocket
Possible Setting Friendly Name: IdealAggressive
Current AC Power Setting Index: 0x00000001 (default: 0x00000002)
Current DC Power Setting Index: 0x00000002
Power Setting GUID: 465e1f50-b610-473a-ab58-00d1077dc419 (Processor performance increase policy for Processor Power Efficiency Class 1)
GUID Alias: PERFINCPOL1
Current AC Power Setting Index: 0x00000001 (default: 0x00000003)
Current DC Power Setting Index: 0x00000003
Power Setting GUID: 893dee8e-2bef-41e0-89c6-b55d0929964c (Minimum processor state)
GUID Alias: PROCTHROTTLEMIN
Current AC Power Setting Index: 0x00000000 (default: 0x00000064)
Current DC Power Setting Index: 0x00000005
Power Setting GUID: be337238-0d82-4146-a960-4f3749d470c7 (Processor performance boost mode)
GUID Alias: PERFBOOSTMODE
Possible Setting Friendly Name: Disabled
Possible Setting Friendly Name: Enabled
Possible Setting Friendly Name: Aggressive
Possible Setting Friendly Name: Efficient Enabled
Possible Setting Index: 004
Possible Setting Friendly Name: Efficient Aggressive
Possible Setting Index: 005
Possible Setting Friendly Name: Aggressive At Guaranteed
Possible Setting Index: 006
Possible Setting Friendly Name: Efficient Aggressive At Guaranteed
so if i compare what i use vs this, mostly the same thing with more power restriction on wireless and pcie and a minimum power state of 0, i will stick with what i currently use
Nah....... don't do that. I see the file now. It's a readme.txt file and a .pow file. (essentially a config file) - and you're right, totally non nefarious.
It's basically just the settings you use , exported to a config file > .pow file. Harmless. I understand now. No biggie.
Question? Would you suggest any changes for a 3700x?
AMD OVERLOCKER
The questions are:
- is the same setup working for other Ryzen too? Like 3600x?
- what are the differences with other popular power plans like the Usmus, etc
Sent from my ONEPLUS A6003 using Tapatalk
1 - 9 of 9 Posts
