To participate in the list all you have to do is download the portable program (no install necessary) Thaiphoon Burner and post a screenshot of your RAM here.
A list of missing RAM kits is at the end of the post.
In general (on Ryzen) you can expect up to 3466 MHz (without BCLK-OC) with Samsung B-Die (on AGESA 1.0.0.6+ Bios Versions), up to 2933 MHz (without BCLK-OC) with Samsung D/E/S-Die (AGESA 1.0.0.5+). Hynix A/M-Die are mostly working @ 3200 MHz with AGESA 1.0.0.5+. Do note that Dual Rank RAM is faster than Single Rank. E.g. 2933 MHz Dual Rank is faster than 3200 MHz Single Rank. Single/Dual Rank is not to be confused with Single/Dual Channel (Dual Channel is always better).
You can expect color subvariants (see legend below) of G.Skill RAM to have the same IC as the regular version. This is why color/RGB versions are listed as the standard version, e.g. GVR -> GVK / GTZKW -> GTZ, unless no "standard" version exists (e.g. F4-3000C15D-16GVR & F4-3000C16D-16GTZR).
Legend:
3000 MHz CL15 & 3200 MHz CL16 are special cases because multiple subtiming versions exist (e.g. CL16-16-16-36 & CL16-18-18-38).
Entries marked with * indicate that you may get Samsung or Hynix IC, both variants exist with the same model number.
K4A8G085WB (Samsung) Memory Chips:
K4A4G085WD (Samsung) Memory Chips:
K4A4G085WE (Samsung) Memory Chips:
K4A4G085WS (Samsung) Memory Chips:
H5AN8G8NAFR/H5AN8G8NMFR (Hynix) Memory Chips:
H5AN4G8NAFR/H5AN4G8NMFR (Hynix) Memory Chips:
16GB (32GB Kit) Module List:
Some of the missing Thaiphoon Screenshots:
Trident Z:
Ripjaws V:
Many 16GB module (32GB kits) are still missing!
Legend:
Model number | Version | Listed Model number |
GFX | Gray Flare X "optimized" for Ryzen | GFX |
GFXR | Red Flare X "optimized" for Ryzen | GFX |
GTZ(A) | Silver/red Trident Z | GTZ(A) |
GTZB | Silver/red Trident Z with higher subtimings | GTZB |
GTZKW | Black/white Trident Z | GTZ |
GTZKO | Black/orange Trident Z | GTZ |
GTZKY | Black/yellow Trident Z | GTZ |
GTZSK | Silver/black Trident Z | GTZ |
GTZSW | Silver/white Trident Z | GTZ |
GTZR | Black/RGB Trident Z | GTZ |
GVK | Black Ripjaws V | GVK |
GVKB/GVGB | Black Ripjaws V with higher subtimings | GVKB |
GVR | Red Ripjaws V | GVK |
GVRB | Red Ripjaws V with higher subtimings | GVKB |
GVS | Silver Ripjaws V | GVK |
Name | Model number | IC | Rank | Sided | Source |
G.Skill Trident Z 3000 MHz CL14 | F4-3000C14D-16GTZ | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Ripjaws V 3000 MHz CL14 | F4-3000C14D-16GVK | 8Gb Samsung B-Die | Single | Single | Jedec Info |
Corsair Dominator 3000 MHz CL15 | CMD16GX4M2B3000C15 | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Flare X 3200 MHz CL14 | F4-3200C14D-16GFX | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3200 MHz CL14 | F4-3200C14D-16GTZ | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Ripjaws V 3200 MHz CL14 | F4-3200C14D-16GVK | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3200 MHz CL15 | F4-3200C15D-16GTZ | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Ripjaws V 3200 MHz CL15 | F4-3200C15D-16GVK | 8Gb Samsung B-Die | Single | Single | Jedec Info |
GeIL Evo X 3200 MHz CL16 | GEX416GB3200C16ADC | 8Gb Samsung B-Die | Single | Single | Jedec Info |
Corsair Vengeance 3400 MHz CL16 | CMU32GX4M4C3400C16 | 8Gb Samsung B-Die | Single | Single | Jedec Info |
Corsair Vengeance 3400 MHz CL16 | CMU32GX4M4B3400C16 | 8Gb Samsung B-Die | Single | Single | Jedec Info |
Corsair Vengeance 3466 MHz CL16 | CMK32GX4M4B3466C16 | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3466 MHz CL16 | F4-3466C16D-16GTZ | 8Gb Samsung B-Die | Single | Single | Jedec Info |
Crucial Elite 3466 MHz CL16 | BLE2K8G4D34AEEAK | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3600 MHz CL15 | F4-3600C15D-16GTZ | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3600 MHz CL16 | F4-3600C16D-16GTZ | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Ripjaws V 3600 MHz CL16 | F4-3600C16D-16GVK | 8Gb Samsung B-Die | Single | Single | Jedec Info |
Corsair Dominator 3600 MHz CL16 | CMD32GX4M4B3600C16 | 8Gb Samsung B-Die | Single | Single | Jedec Info |
Corsair Vengeance 3600 MHz CL16 | CMK32GX4M4B3600C16 | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3600 MHz CL17 | F4-3600C17D-16GTZ | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Ripjaws V 3600 MHz CL17 | F4-3600C17D-16GVK | 8Gb Samsung B-Die | Single | Single | Jedec Info |
KFA2 HOF 3600 MHz CL17 | HOF4CXLBS3600K17LD162K | 8Gb Samsung B-Die | Single | Single | Jedec Info |
Corsair Vengeance 3600 MHz CL18 | CMK32GX4M4B3600C18 | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3733 MHz CL17 | F4-3733C17D-16GTZA | 8Gb Samsung B-Die | Single | Single | Jedec Info |
Teamgroup T-Force 3733 MHz CL18 | TXD416G3733HC18ADC01 | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3866 MHz CL18 | F4-3866C18D-16GTZ | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 4000 MHz CL18 | F4-4000C18D-16GTZ | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 4000 MHz CL19 | F4-4000C19D-16GTZ | 8Gb Samsung B-Die | Single | Single | Jedec Info |
Corsair Vengeance 4000 MHz CL19 | CMK32GX4M4B4000C19 | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 4133 MHz CL19 | F4-4133C19D-16GTZA | 8Gb Samsung B-Die | Single | Single | Jedec Info |
G.Skill Trident Z 4266 MHz CL19 | F4-4266C19D-16GTZ | 8Gb Samsung B-Die | Single | Single | Jedec Info |
GeIL Dragon 3000 MHz CL15 | GWW416GB3000C15DC | 4Gb Samsung D-Die | Dual | Double | Jedec Info |
G.Skill Trident Z 3000 MHz CL15* | F4-3000C15D-16GTZ | 4Gb Samsung D-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws 4 3000 MHz CL15 | F4-3000C15Q-32GRKB | 4Gb Samsung D-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws V 3200 MHz CL16* | F4-3200C16D-16GVK | 4Gb Samsung D-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws V 3200 MHz CL16* | F4-3200C16D-16GVKB | 4Gb Samsung D-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws V 3333 MHz CL16 | F4-3333C16D-16GVK | 4Gb Samsung D-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws V 3400 MHz CL16 | F4-3400C16D-16GVK | 4Gb Samsung D-Die | Dual | Double | Jedec Info |
G.Skill Trident Z 3000 MHz CL15 | F4-3000C15D-16GTZB | 4Gb Samsung E-Die | Dual | Double | Jedec Info |
G.Skill Trident Z 3200 MHz CL16* | F4-3200C16D-16GTZ | 4Gb Samsung E-Die | Dual | Double | Jedec Info |
G.Skill Trident Z 3200 MHz CL16* | F4-3200C16D-16GTZB | 4Gb Samsung E-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws V 3200 MHz CL16 | F4-3200C16D-16GVGB | 4Gb Samsung E-Die | Dual | Double | Jedec Info |
G.Skill Trident Z 3400 MHz CL16 | F4-3400C16D-16GTZ | 4Gb Samsung E-Die | Dual | Double | Jedec Info |
TeamGroup T-Force 3200 MHz CL16 | THRD416G3200HC16CDC01 | 4Gb Samsung S-Die | Dual | Double | Jedec Info |
TeamGroup T-Force 3200 MHz CL16 | THWD416G3200HC16CDC01 | 4Gb Samsung S-Die | Dual | Double | Jedec Info |
TeamGroup T-Force 3200 MHz CL16 | THBD416G3200HC16CDC01 | 4Gb Samsung S-Die | Dual | Double | Jedec Info |
G.Skill Flare X 2400 MHz CL15 | F4-2400C15D-16GFX | 8Gb Hynix ?-Die | Single | Single | Jedec Info |
G.Skill Trident Z 2400 MHz CL15 | F4-2400C15D-16GTZR | 8Gb Hynix A-Die | Single | Single | Jedec Info |
Corsair Vengeance 2600 MHz CL16 | CMK16GX4M2B2666C16 | 8Gb Hynix A-Die | Single | Single | Jedec Info |
G.Skill Ripjaws V 2800 MHz CL16 | F4-2800C16D-16GVG | 8Gb Hynix M-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3000 MHz CL15* | F4-3000C15D-16GTZ | 8Gb Hynix A-Die | Single | Single | Jedec Info |
G.Skill Ripjaws V 3000 MHz CL15 | F4-3000C15D-16GVKB | 8Gb Hynix M-Die | Single | Single | Jedec Info |
Corsair Vengeance 3000 MHz CL15 | CMK16GX4M2B3000C15 | 8Gb Hynix M-Die | Single | Single | Jedec Info |
Corsair Vengeance 3000 MHz CL15 | CMK16GX4M2B3000C15 | 8Gb Hynix ?-Die | Single | Single | Jedec Info |
TeamGroup T-Force 3000 MHz CL16 | TLRED416G3000HC16CDC01 | 8Gb Hynix M-Die | Single | Single | Jedec Info |
G.Skill Aegis 3000 MHz CL16 | F4-3000C16D-16GISB | 8Gb Hynix M-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3000 MHz CL16 | F4-3000C16D-16GTZR | 8Gb Hynix A-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3200 MHz CL16* | F4-3200C16D-16GTZ | 8Gb Hynix M-Die | Single | Single | Jedec Info |
G.Skill Trident Z 3200 MHz CL16* | F4-3200C16D-16GTZR | 8Gb Hynix A-Die | Single | Single | Jedec Info |
G.Skill Ripjaws V 3200 MHz CL16* | F4-3200C16D-16GVKB | 8Gb Hynix M-Die | Single | Single | Jedec Info |
Corsair Vengeance 3200 MHz CL16 | CMK16GX4M2B3200C16 | 8Gb Hynix ?-Die | Single | Single | Jedec Info |
EVGA SuperSC 3200 MHz CL16 | 8GX-D4-3200-MR | 8Gb Hynix ?-Die | Single | Single | Jedec Info |
Kingston Predator 3200 MHz CL16 | HX432C16PB3K2/16 | 8Gb Hynix M-Die | Single | Single | Jedec Info |
Kingston Predator 3333 MHz CL16 | HX433C16PB3K2/16 | 8Gb Hynix ?-Die | Single | Single | Jedec Info |
G.Skill Ripjaws V 2400 MHz CL15 | F4-2400C15D-16GVR | 4Gb Hynix M-Die | Dual | Double | Jedec Info |
Kingston Savage 3000 MHz CL15 | HX430C15SB2K2/16 | 4Gb Hynix A-Die | Dual | Double | Jedec Info |
G.Skill Flare X 2400 MHz CL15 | F4-2400C15D-32GFX | 8Gb Hynix ?-Die | Dual | Double | Jedec Info |
Crucial Sport 2666 MHz CL16 | BLS2K16G4D26BFSC | 8Gb Micron B-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws V 2800 MHz CL14 | F4-2800C14D-32GVK | 8Gb Samsung B-Die | Dual | Double | Jedec Info |
G.Skill Trident Z 3000 MHz CL14 | F4-3000C14D-32GTZ | 8Gb Samsung B-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws V 3000 MHz CL14 | F4-3000C14D-32GVK | 8Gb Samsung B-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws V 3000 MHz CL15 | F4-3000C15D-32GVR | 8Gb Hynix M-Die | Dual | Double | Jedec Info |
Corsair Vengeance 3000 MHz CL15 | CMK32GX4M2B3000C15 | 8Gb Hynix ?-Die | Dual | Double | Jedec Info |
G.Skill Trident Z 3200 MHz CL14 | F4-3200C14D-32GTZ | 8Gb Samsung B-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws V 3200 MHz CL14 | F4-3200C14D-32GVK | 8Gb Samsung B-Die | Dual | Double | Jedec Info |
G.Skill Trident Z 3200 MHz CL15 | F4-3200C15D-32GTZ | 8Gb Samsung B-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws V 3200 MHz CL15 | F4-3200C15D-32GVK | 8Gb Samsung B-Die | Dual | Double | Jedec Info |
G.Skill Trident Z 3200 MHz CL16 | F4-3200C16D-32GTZA | 8Gb Samsung B-Die | Dual | Double | Jedec Info |
G.Skill Ripjaws V 3200 MHz CL16 | F4-3200C16D-32GVK | 8Gb Hynix M-Die | Dual | Double | Jedec Info |
G.Skill Trident Z 3400 MHz CL16 | F4-3400C16D-32GTZ | 8Gb Samsung B-Die | Dual | Double | Jedec Info |
Trident Z:
- F4-2800C15D-16GTZ
- F4-2800C15D-16GTZB
- F4-3000C15D-16GTZB
Ripjaws V:
- F4-2800C15D-16GVSB
- F4-2800C15D-16GVR
- F4-3000C15D-16GVKB
- F4-3000C15D-16GVGB
- F4-3466C16D-16GVK
