Ryzen Memory IC Collection Thread
244008 181
To participate in the list all you have to do is download the portable program (no install necessary) Thaiphoon Burner and post a screenshot of your RAM here.
A list of missing RAM kits is at the end of the post.
In general (on Ryzen) you can expect up to 3466 MHz (without BCLK-OC) with Samsung B-Die (on AGESA 1.0.0.6+ Bios Versions), up to 2933 MHz (without BCLK-OC) with Samsung D/E/S-Die (AGESA 1.0.0.5+). Hynix A/M-Die are mostly working @ 3200 MHz with AGESA 1.0.0.5+. Do note that Dual Rank RAM is faster than Single Rank. E.g. 2933 MHz Dual Rank is faster than 3200 MHz Single Rank. Single/Dual Rank is not to be confused with Single/Dual Channel (Dual Channel is always better).
You can expect color subvariants (see legend below) of G.Skill RAM to have the same IC as the regular version. This is why color/RGB versions are listed as the standard version, e.g. GVR -> GVK / GTZKW -> GTZ, unless no "standard" version exists (e.g. F4-3000C15D-16GVR & F4-3000C16D-16GTZR).
Legend:
Model numberVersionListed Model number
GFXGray Flare X "optimized" for RyzenGFX
GFXRRed Flare X "optimized" for RyzenGFX
GTZ(A)Silver/red Trident ZGTZ(A)
GTZBSilver/red Trident Z with higher subtimingsGTZB
GTZKWBlack/white Trident ZGTZ
GTZKOBlack/orange Trident ZGTZ
GTZKYBlack/yellow Trident ZGTZ
GTZSKSilver/black Trident ZGTZ
GTZSWSilver/white Trident ZGTZ
GTZRBlack/RGB Trident ZGTZ
GVKBlack Ripjaws VGVK
GVKB/GVGBBlack Ripjaws V with higher subtimingsGVKB
GVRRed Ripjaws VGVK
GVRBRed Ripjaws V with higher subtimingsGVKB
GVSSilver Ripjaws VGVK
3000 MHz CL15 & 3200 MHz CL16 are special cases because multiple subtiming versions exist (e.g. CL16-16-16-36 & CL16-18-18-38).
Entries marked with * indicate that you may get Samsung or Hynix IC, both variants exist with the same model number.
K4A8G085WB (Samsung) Memory Chips:
NameModel numberICRankSidedSource
G.Skill Trident Z 3000 MHz CL14F4-3000C14D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3000 MHz CL14F4-3000C14D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
Corsair Dominator 3000 MHz CL15CMD16GX4M2B3000C158Gb Samsung B-DieSingleSingleJedec Info
G.Skill Flare X 3200 MHz CL14F4-3200C14D-16GFX8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL14F4-3200C14D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3200 MHz CL14F4-3200C14D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL15F4-3200C15D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3200 MHz CL15F4-3200C15D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
GeIL Evo X 3200 MHz CL16GEX416GB3200C16ADC8Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3400 MHz CL16CMU32GX4M4C3400C168Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3400 MHz CL16CMU32GX4M4B3400C168Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3466 MHz CL16CMK32GX4M4B3466C168Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3466 MHz CL16F4-3466C16D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
Crucial Elite 3466 MHz CL16BLE2K8G4D34AEEAK8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3600 MHz CL15F4-3600C15D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3600 MHz CL16F4-3600C16D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3600 MHz CL16F4-3600C16D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
Corsair Dominator 3600 MHz CL16CMD32GX4M4B3600C168Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3600 MHz CL16CMK32GX4M4B3600C168Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3600 MHz CL17F4-3600C17D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3600 MHz CL17F4-3600C17D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
KFA2 HOF 3600 MHz CL17HOF4CXLBS3600K17LD162K8Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3600 MHz CL18CMK32GX4M4B3600C188Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3733 MHz CL17F4-3733C17D-16GTZA8Gb Samsung B-DieSingleSingleJedec Info
Teamgroup T-Force 3733 MHz CL18TXD416G3733HC18ADC018Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3866 MHz CL18F4-3866C18D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4000 MHz CL18F4-4000C18D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4000 MHz CL19F4-4000C19D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 4000 MHz CL19CMK32GX4M4B4000C198Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4133 MHz CL19F4-4133C19D-16GTZA8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4266 MHz CL19F4-4266C19D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
K4A4G085WD (Samsung) Memory Chips:
GeIL Dragon 3000 MHz CL15GWW416GB3000C15DC4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Trident Z 3000 MHz CL15*F4-3000C15D-16GTZ4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws 4 3000 MHz CL15F4-3000C15Q-32GRKB4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16*F4-3200C16D-16GVK4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16*F4-3200C16D-16GVKB4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3333 MHz CL16F4-3333C16D-16GVK4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3400 MHz CL16F4-3400C16D-16GVK4Gb Samsung D-DieDualDoubleJedec Info
K4A4G085WE (Samsung) Memory Chips:
G.Skill Trident Z 3000 MHz CL15F4-3000C15D-16GTZB4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZ4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZB4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16F4-3200C16D-16GVGB4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Trident Z 3400 MHz CL16F4-3400C16D-16GTZ4Gb Samsung E-DieDualDoubleJedec Info
K4A4G085WS (Samsung) Memory Chips:
TeamGroup T-Force 3200 MHz CL16THRD416G3200HC16CDC014Gb Samsung S-DieDualDoubleJedec Info
TeamGroup T-Force 3200 MHz CL16THWD416G3200HC16CDC014Gb Samsung S-DieDualDoubleJedec Info
TeamGroup T-Force 3200 MHz CL16THBD416G3200HC16CDC014Gb Samsung S-DieDualDoubleJedec Info
H5AN8G8NAFR/H5AN8G8NMFR (Hynix) Memory Chips:
G.Skill Flare X 2400 MHz CL15F4-2400C15D-16GFX8Gb Hynix ?-DieSingleSingleJedec Info
G.Skill Trident Z 2400 MHz CL15F4-2400C15D-16GTZR8Gb Hynix A-DieSingleSingleJedec Info
Corsair Vengeance 2600 MHz CL16CMK16GX4M2B2666C168Gb Hynix A-DieSingleSingleJedec Info
G.Skill Ripjaws V 2800 MHz CL16F4-2800C16D-16GVG8Gb Hynix M-DieSingleSingleJedec Info
G.Skill Trident Z 3000 MHz CL15*F4-3000C15D-16GTZ8Gb Hynix A-DieSingleSingleJedec Info
G.Skill Ripjaws V 3000 MHz CL15F4-3000C15D-16GVKB8Gb Hynix M-DieSingleSingleJedec Info
Corsair Vengeance 3000 MHz CL15CMK16GX4M2B3000C158Gb Hynix M-DieSingleSingleJedec Info
Corsair Vengeance 3000 MHz CL15CMK16GX4M2B3000C158Gb Hynix ?-DieSingleSingleJedec Info
TeamGroup T-Force 3000 MHz CL16TLRED416G3000HC16CDC018Gb Hynix M-DieSingleSingleJedec Info
G.Skill Aegis 3000 MHz CL16F4-3000C16D-16GISB8Gb Hynix M-DieSingleSingleJedec Info
G.Skill Trident Z 3000 MHz CL16F4-3000C16D-16GTZR8Gb Hynix A-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZ8Gb Hynix M-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZR8Gb Hynix A-DieSingleSingleJedec Info
G.Skill Ripjaws V 3200 MHz CL16*F4-3200C16D-16GVKB8Gb Hynix M-DieSingleSingleJedec Info
Corsair Vengeance 3200 MHz CL16CMK16GX4M2B3200C168Gb Hynix ?-DieSingleSingleJedec Info
EVGA SuperSC 3200 MHz CL168GX-D4-3200-MR8Gb Hynix ?-DieSingleSingleJedec Info
Kingston Predator 3200 MHz CL16HX432C16PB3K2/168Gb Hynix M-DieSingleSingleJedec Info
Kingston Predator 3333 MHz CL16HX433C16PB3K2/168Gb Hynix ?-DieSingleSingleJedec Info
H5AN4G8NAFR/H5AN4G8NMFR (Hynix) Memory Chips:
G.Skill Ripjaws V 2400 MHz CL15F4-2400C15D-16GVR4Gb Hynix M-DieDualDoubleJedec Info
Kingston Savage 3000 MHz CL15HX430C15SB2K2/164Gb Hynix A-DieDualDoubleJedec Info
16GB (32GB Kit) Module List:
G.Skill Flare X 2400 MHz CL15F4-2400C15D-32GFX8Gb Hynix ?-DieDualDoubleJedec Info
Crucial Sport 2666 MHz CL16BLS2K16G4D26BFSC8Gb Micron B-DieDualDoubleJedec Info
G.Skill Ripjaws V 2800 MHz CL14F4-2800C14D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Trident Z 3000 MHz CL14F4-3000C14D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3000 MHz CL14F4-3000C14D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3000 MHz CL15F4-3000C15D-32GVR8Gb Hynix M-DieDualDoubleJedec Info
Corsair Vengeance 3000 MHz CL15CMK32GX4M2B3000C158Gb Hynix ?-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL14F4-3200C14D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL14F4-3200C14D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL15F4-3200C15D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL15F4-3200C15D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL16F4-3200C16D-32GTZA8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16F4-3200C16D-32GVK8Gb Hynix M-DieDualDoubleJedec Info
G.Skill Trident Z 3400 MHz CL16F4-3400C16D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
Some of the missing Thaiphoon Screenshots:
Trident Z:
  • F4-2800C15D-16GTZ
  • F4-2800C15D-16GTZB
  • F4-3000C15D-16GTZB
Ripjaws V:
  • F4-2800C15D-16GVSB
  • F4-2800C15D-16GVR
  • F4-3000C15D-16GVKB
  • F4-3000C15D-16GVGB
  • F4-3466C16D-16GVK
Many 16GB module (32GB kits) are still missing!
Reactions: Aenra and sydefekt
181 - 182 of 182 Posts
@aepseidhe Thank you for the photo, will add the SKU with the next update later today. Is it known if these were sold in retail or if they were part of a prebuilt system?
np - as I will be at home ( in one month I guess) I will make photo of 2x16 GB - they were sold on polish e-bay equivalent by company which described them as OEM (so no for retail) - no additional info was provided.
Guys is there any bin difference between these two models F4-4000C17D-32GVKB and F4-4266C17D-32GVKB, the first one is at 1.4v and the second one at 1.5v, I was looking for the second one but at the moment is almost impossible to be found. I will watercool the kit to push it at 1.55 / 1.6v
