Ryzen Memory IC Collection Thread
244148 Views 181 Replies 111 Participants Last post by  Biscottoman
To participate in the list all you have to do is download the portable program (no install necessary) Thaiphoon Burner and post a screenshot of your RAM here.
A list of missing RAM kits is at the end of the post.
In general (on Ryzen) you can expect up to 3466 MHz (without BCLK-OC) with Samsung B-Die (on AGESA 1.0.0.6+ Bios Versions), up to 2933 MHz (without BCLK-OC) with Samsung D/E/S-Die (AGESA 1.0.0.5+). Hynix A/M-Die are mostly working @ 3200 MHz with AGESA 1.0.0.5+. Do note that Dual Rank RAM is faster than Single Rank. E.g. 2933 MHz Dual Rank is faster than 3200 MHz Single Rank. Single/Dual Rank is not to be confused with Single/Dual Channel (Dual Channel is always better).
You can expect color subvariants (see legend below) of G.Skill RAM to have the same IC as the regular version. This is why color/RGB versions are listed as the standard version, e.g. GVR -> GVK / GTZKW -> GTZ, unless no "standard" version exists (e.g. F4-3000C15D-16GVR & F4-3000C16D-16GTZR).
Legend:
Model numberVersionListed Model number
GFXGray Flare X "optimized" for RyzenGFX
GFXRRed Flare X "optimized" for RyzenGFX
GTZ(A)Silver/red Trident ZGTZ(A)
GTZBSilver/red Trident Z with higher subtimingsGTZB
GTZKWBlack/white Trident ZGTZ
GTZKOBlack/orange Trident ZGTZ
GTZKYBlack/yellow Trident ZGTZ
GTZSKSilver/black Trident ZGTZ
GTZSWSilver/white Trident ZGTZ
GTZRBlack/RGB Trident ZGTZ
GVKBlack Ripjaws VGVK
GVKB/GVGBBlack Ripjaws V with higher subtimingsGVKB
GVRRed Ripjaws VGVK
GVRBRed Ripjaws V with higher subtimingsGVKB
GVSSilver Ripjaws VGVK
3000 MHz CL15 & 3200 MHz CL16 are special cases because multiple subtiming versions exist (e.g. CL16-16-16-36 & CL16-18-18-38).
Entries marked with * indicate that you may get Samsung or Hynix IC, both variants exist with the same model number.
K4A8G085WB (Samsung) Memory Chips:
NameModel numberICRankSidedSource
G.Skill Trident Z 3000 MHz CL14F4-3000C14D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3000 MHz CL14F4-3000C14D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
Corsair Dominator 3000 MHz CL15CMD16GX4M2B3000C158Gb Samsung B-DieSingleSingleJedec Info
G.Skill Flare X 3200 MHz CL14F4-3200C14D-16GFX8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL14F4-3200C14D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3200 MHz CL14F4-3200C14D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL15F4-3200C15D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3200 MHz CL15F4-3200C15D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
GeIL Evo X 3200 MHz CL16GEX416GB3200C16ADC8Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3400 MHz CL16CMU32GX4M4C3400C168Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3400 MHz CL16CMU32GX4M4B3400C168Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3466 MHz CL16CMK32GX4M4B3466C168Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3466 MHz CL16F4-3466C16D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
Crucial Elite 3466 MHz CL16BLE2K8G4D34AEEAK8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3600 MHz CL15F4-3600C15D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3600 MHz CL16F4-3600C16D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3600 MHz CL16F4-3600C16D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
Corsair Dominator 3600 MHz CL16CMD32GX4M4B3600C168Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3600 MHz CL16CMK32GX4M4B3600C168Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3600 MHz CL17F4-3600C17D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3600 MHz CL17F4-3600C17D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
KFA2 HOF 3600 MHz CL17HOF4CXLBS3600K17LD162K8Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3600 MHz CL18CMK32GX4M4B3600C188Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3733 MHz CL17F4-3733C17D-16GTZA8Gb Samsung B-DieSingleSingleJedec Info
Teamgroup T-Force 3733 MHz CL18TXD416G3733HC18ADC018Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3866 MHz CL18F4-3866C18D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4000 MHz CL18F4-4000C18D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4000 MHz CL19F4-4000C19D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 4000 MHz CL19CMK32GX4M4B4000C198Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4133 MHz CL19F4-4133C19D-16GTZA8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4266 MHz CL19F4-4266C19D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
K4A4G085WD (Samsung) Memory Chips:
GeIL Dragon 3000 MHz CL15GWW416GB3000C15DC4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Trident Z 3000 MHz CL15*F4-3000C15D-16GTZ4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws 4 3000 MHz CL15F4-3000C15Q-32GRKB4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16*F4-3200C16D-16GVK4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16*F4-3200C16D-16GVKB4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3333 MHz CL16F4-3333C16D-16GVK4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3400 MHz CL16F4-3400C16D-16GVK4Gb Samsung D-DieDualDoubleJedec Info
K4A4G085WE (Samsung) Memory Chips:
G.Skill Trident Z 3000 MHz CL15F4-3000C15D-16GTZB4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZ4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZB4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16F4-3200C16D-16GVGB4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Trident Z 3400 MHz CL16F4-3400C16D-16GTZ4Gb Samsung E-DieDualDoubleJedec Info
K4A4G085WS (Samsung) Memory Chips:
TeamGroup T-Force 3200 MHz CL16THRD416G3200HC16CDC014Gb Samsung S-DieDualDoubleJedec Info
TeamGroup T-Force 3200 MHz CL16THWD416G3200HC16CDC014Gb Samsung S-DieDualDoubleJedec Info
TeamGroup T-Force 3200 MHz CL16THBD416G3200HC16CDC014Gb Samsung S-DieDualDoubleJedec Info
H5AN8G8NAFR/H5AN8G8NMFR (Hynix) Memory Chips:
G.Skill Flare X 2400 MHz CL15F4-2400C15D-16GFX8Gb Hynix ?-DieSingleSingleJedec Info
G.Skill Trident Z 2400 MHz CL15F4-2400C15D-16GTZR8Gb Hynix A-DieSingleSingleJedec Info
Corsair Vengeance 2600 MHz CL16CMK16GX4M2B2666C168Gb Hynix A-DieSingleSingleJedec Info
G.Skill Ripjaws V 2800 MHz CL16F4-2800C16D-16GVG8Gb Hynix M-DieSingleSingleJedec Info
G.Skill Trident Z 3000 MHz CL15*F4-3000C15D-16GTZ8Gb Hynix A-DieSingleSingleJedec Info
G.Skill Ripjaws V 3000 MHz CL15F4-3000C15D-16GVKB8Gb Hynix M-DieSingleSingleJedec Info
Corsair Vengeance 3000 MHz CL15CMK16GX4M2B3000C158Gb Hynix M-DieSingleSingleJedec Info
Corsair Vengeance 3000 MHz CL15CMK16GX4M2B3000C158Gb Hynix ?-DieSingleSingleJedec Info
TeamGroup T-Force 3000 MHz CL16TLRED416G3000HC16CDC018Gb Hynix M-DieSingleSingleJedec Info
G.Skill Aegis 3000 MHz CL16F4-3000C16D-16GISB8Gb Hynix M-DieSingleSingleJedec Info
G.Skill Trident Z 3000 MHz CL16F4-3000C16D-16GTZR8Gb Hynix A-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZ8Gb Hynix M-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZR8Gb Hynix A-DieSingleSingleJedec Info
G.Skill Ripjaws V 3200 MHz CL16*F4-3200C16D-16GVKB8Gb Hynix M-DieSingleSingleJedec Info
Corsair Vengeance 3200 MHz CL16CMK16GX4M2B3200C168Gb Hynix ?-DieSingleSingleJedec Info
EVGA SuperSC 3200 MHz CL168GX-D4-3200-MR8Gb Hynix ?-DieSingleSingleJedec Info
Kingston Predator 3200 MHz CL16HX432C16PB3K2/168Gb Hynix M-DieSingleSingleJedec Info
Kingston Predator 3333 MHz CL16HX433C16PB3K2/168Gb Hynix ?-DieSingleSingleJedec Info
H5AN4G8NAFR/H5AN4G8NMFR (Hynix) Memory Chips:
G.Skill Ripjaws V 2400 MHz CL15F4-2400C15D-16GVR4Gb Hynix M-DieDualDoubleJedec Info
Kingston Savage 3000 MHz CL15HX430C15SB2K2/164Gb Hynix A-DieDualDoubleJedec Info
16GB (32GB Kit) Module List:
G.Skill Flare X 2400 MHz CL15F4-2400C15D-32GFX8Gb Hynix ?-DieDualDoubleJedec Info
Crucial Sport 2666 MHz CL16BLS2K16G4D26BFSC8Gb Micron B-DieDualDoubleJedec Info
G.Skill Ripjaws V 2800 MHz CL14F4-2800C14D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Trident Z 3000 MHz CL14F4-3000C14D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3000 MHz CL14F4-3000C14D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3000 MHz CL15F4-3000C15D-32GVR8Gb Hynix M-DieDualDoubleJedec Info
Corsair Vengeance 3000 MHz CL15CMK32GX4M2B3000C158Gb Hynix ?-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL14F4-3200C14D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL14F4-3200C14D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL15F4-3200C15D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL15F4-3200C15D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL16F4-3200C16D-32GTZA8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16F4-3200C16D-32GVK8Gb Hynix M-DieDualDoubleJedec Info
G.Skill Trident Z 3400 MHz CL16F4-3400C16D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
Some of the missing Thaiphoon Screenshots:
Trident Z:
  • F4-2800C15D-16GTZ
  • F4-2800C15D-16GTZB
  • F4-3000C15D-16GTZB
Ripjaws V:
  • F4-2800C15D-16GVSB
  • F4-2800C15D-16GVR
  • F4-3000C15D-16GVKB
  • F4-3000C15D-16GVGB
  • F4-3466C16D-16GVK
Many 16GB module (32GB kits) are still missing!
Reactions: Aenra and sydefekt
21 - 40 of 182 Posts
· ⤷ αC
Dumped Micocenter's EVGA SuperSC DDR4 3200MHz (16-18-18-38 1.35V labeled) via Linux
# decode-dimms version 6231 (2014-02-20 10:54:34 +0100)
Memory Serial Presence Detect Decoder
By Philip Edelbrock, Christian Zuckschwerdt, Burkart Lingner,
Jean Delvare, Trent Piepho and others
Decoding EEPROM: /sys/bus/i2c/drivers/eeprom/10-0052
Guessing DIMM is in bank 3
---=== SPD EEPROM Information ===---
EEPROM CRC of bytes 0-125 OK (0x242D)
# of bytes written to SDRAM EEPROM 256
Total number of bytes in EEPROM 512
Fundamental Memory type Unknown (0x0c)
---=== Manufacturing Information ===---
Manufacturer Synertek
Custom Manufacturer Data 36 16 36 00 00 16 36 ("6?6???6")
Manufacturing Location Code 0x16
Part Number 6
Decoding EEPROM: /sys/bus/i2c/drivers/eeprom/10-0053
Guessing DIMM is in bank 4
Part Number 6
Number of SDRAM DIMMs detected and decoded: 2
In retrospect I should not have gotten them but I was really curious about the ICs
Windows 10 PE hwinfo lists Hynix
AIDA64 result
I will try for a Thaiphoon burner shot on Windows (using liveUSB right now)
Thaiphoon burner
Geil EVO X 3200 CL 16 is listed as Samsung B die on your list but there are also kits with that same part number that have Hynix ?FR chips.
Full name of the kit : GEX416GB3200C16DC
Single Rank 2x8GB
Presumably AFR chips but i cant tell for sure.
Here a screenshot that tells it is Hynix :
· ⤷ αC
https://translate.google.com/translate?hl=en&sl=ru&tl=en&u=https%3A%2F%2Fwww.overclockers.ru%2Flab%2F85777%2Fobzor-i-test-chetyreh-modulej-operativnoj-pamyati-ddr4-2133-amd-radeon-r7-r748g2133u2s-obemom-8-gbajt-na-platformah-intel-kaby-lake-i-amd-ryzen-agesa-1-0-0-6a.html
AMD Radeon R7 R748G2133U2S Memory
Green
H5AN4G8NMFR-TFC
Black
SK Hynix H5AN4G8N * FR-TFC
Horrible decision by AMD.
They could have improved platform compatibility across the board by releasing Samsung B-die at a reasonable price for black PCB R7 branded RAM , with the green 2400MHz DIMMs (Hynix/Micron/etc) for Ryzen 5 and Ryzen 3 builds. That's essentially what GSkill FlareX is doing. Instead we get a poor version of Gskill Fortis.
Could someone confirm if the Corsair Dominator 3466 C16 CMD16GX4M2B3466C16 is using the Samsung B die?
· Not New to Overclock.net
Your XMP profile corresponds to DDR4-3200 bin. G.SKILL made something wrong when programming the XMP profile. I would RMA your kit or flash the correct XMP profile from F4-3600C15-8GTZ SPD which you can find in the SPD database of Thaiphoon Burner.
Oddly, upon a double check, it's reporting properly now? Not sure why the first result was binned as that?
Team Group Model#: TLGD416G2400HC15BBK
16gb sticks (2x16gb), advertised as 2400mhz 15-17-17-35 1.2v
Currently I've been running it at 3333mhz, with the advertised clocks. 15-17-17-17-35-1T are set manually, which helped, and the rest are on auto. This is on an ASUS B350-f gaming board. The clock that, uh, follows 35 (I'm a novice) has set itself to 76 at this speed . It's 53 or 52 in the xmp profile, depending on what program you ask, but my board did NOT like taking that setting off of auto.
My Ryzen 1600 is at stock, as I've been overclocking memory first. I'll probably drop the memory down to 3200 for stability & on the assumption that overclocking the CPU may add some stress to the system. Voltages haven't needed much. I upped the DRAM voltage to 1.35v and VTTDDR to the corresponding .675v. SOC increased itself automatically from .9v to 1.1v on my board, so I removed the offset I'd initially programmed in. It's not quite stable. The memory managed 8 hours of Prime95 blend just fine (and I randomly threw a pointless hour of Aida64 memory+cache test at it with no problems), but 5 passes of Memtest86 found 2 errors. Assuming a little voltage or dropping to 3200 gets it stable after I overclock the CPU, I'm EXTREMELY happy with the purchase, as it was basically the cheapest 32gb kit I could find new at the time. Dunno if I got lucky in the silicon lottery, or it after the new BIOS updates there's not much reason to stay away from random Hynix sticks anymore.
Edit: if experienced overclockers have advice re: where timings need to be tighter, even if it gives up mhz or on possibly stabilizing it without dropping to 3200mhz, I'm all ears.
Team T-Force / Night Hawk 64GB (4 x 16GB) DDR4 3200 CL16-18-18-38 Model THWD432G3200HC16CDC01
On Asus Zenith Extreme, 1950X, I was not able to post at 3200 with DOCP. I was able to post at 3066 in DOCP. No tweaking yet, but will try later.
Ran Prime95 for over two hours.
Samsung 'B' die.
