Ryzen Memory IC Collection Thread
244008 181
To participate in the list all you have to do is download the portable program (no install necessary) Thaiphoon Burner and post a screenshot of your RAM here.
A list of missing RAM kits is at the end of the post.
In general (on Ryzen) you can expect up to 3466 MHz (without BCLK-OC) with Samsung B-Die (on AGESA 1.0.0.6+ Bios Versions), up to 2933 MHz (without BCLK-OC) with Samsung D/E/S-Die (AGESA 1.0.0.5+). Hynix A/M-Die are mostly working @ 3200 MHz with AGESA 1.0.0.5+. Do note that Dual Rank RAM is faster than Single Rank. E.g. 2933 MHz Dual Rank is faster than 3200 MHz Single Rank. Single/Dual Rank is not to be confused with Single/Dual Channel (Dual Channel is always better).
You can expect color subvariants (see legend below) of G.Skill RAM to have the same IC as the regular version. This is why color/RGB versions are listed as the standard version, e.g. GVR -> GVK / GTZKW -> GTZ, unless no "standard" version exists (e.g. F4-3000C15D-16GVR & F4-3000C16D-16GTZR).
Legend:
Model numberVersionListed Model number
GFXGray Flare X "optimized" for RyzenGFX
GFXRRed Flare X "optimized" for RyzenGFX
GTZ(A)Silver/red Trident ZGTZ(A)
GTZBSilver/red Trident Z with higher subtimingsGTZB
GTZKWBlack/white Trident ZGTZ
GTZKOBlack/orange Trident ZGTZ
GTZKYBlack/yellow Trident ZGTZ
GTZSKSilver/black Trident ZGTZ
GTZSWSilver/white Trident ZGTZ
GTZRBlack/RGB Trident ZGTZ
GVKBlack Ripjaws VGVK
GVKB/GVGBBlack Ripjaws V with higher subtimingsGVKB
GVRRed Ripjaws VGVK
GVRBRed Ripjaws V with higher subtimingsGVKB
GVSSilver Ripjaws VGVK
3000 MHz CL15 & 3200 MHz CL16 are special cases because multiple subtiming versions exist (e.g. CL16-16-16-36 & CL16-18-18-38).
Entries marked with * indicate that you may get Samsung or Hynix IC, both variants exist with the same model number.
K4A8G085WB (Samsung) Memory Chips:
NameModel numberICRankSidedSource
G.Skill Trident Z 3000 MHz CL14F4-3000C14D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3000 MHz CL14F4-3000C14D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
Corsair Dominator 3000 MHz CL15CMD16GX4M2B3000C158Gb Samsung B-DieSingleSingleJedec Info
G.Skill Flare X 3200 MHz CL14F4-3200C14D-16GFX8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL14F4-3200C14D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3200 MHz CL14F4-3200C14D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL15F4-3200C15D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3200 MHz CL15F4-3200C15D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
GeIL Evo X 3200 MHz CL16GEX416GB3200C16ADC8Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3400 MHz CL16CMU32GX4M4C3400C168Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3400 MHz CL16CMU32GX4M4B3400C168Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3466 MHz CL16CMK32GX4M4B3466C168Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3466 MHz CL16F4-3466C16D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
Crucial Elite 3466 MHz CL16BLE2K8G4D34AEEAK8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3600 MHz CL15F4-3600C15D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3600 MHz CL16F4-3600C16D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3600 MHz CL16F4-3600C16D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
Corsair Dominator 3600 MHz CL16CMD32GX4M4B3600C168Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3600 MHz CL16CMK32GX4M4B3600C168Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3600 MHz CL17F4-3600C17D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Ripjaws V 3600 MHz CL17F4-3600C17D-16GVK8Gb Samsung B-DieSingleSingleJedec Info
KFA2 HOF 3600 MHz CL17HOF4CXLBS3600K17LD162K8Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 3600 MHz CL18CMK32GX4M4B3600C188Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3733 MHz CL17F4-3733C17D-16GTZA8Gb Samsung B-DieSingleSingleJedec Info
Teamgroup T-Force 3733 MHz CL18TXD416G3733HC18ADC018Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 3866 MHz CL18F4-3866C18D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4000 MHz CL18F4-4000C18D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4000 MHz CL19F4-4000C19D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
Corsair Vengeance 4000 MHz CL19CMK32GX4M4B4000C198Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4133 MHz CL19F4-4133C19D-16GTZA8Gb Samsung B-DieSingleSingleJedec Info
G.Skill Trident Z 4266 MHz CL19F4-4266C19D-16GTZ8Gb Samsung B-DieSingleSingleJedec Info
K4A4G085WD (Samsung) Memory Chips:
GeIL Dragon 3000 MHz CL15GWW416GB3000C15DC4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Trident Z 3000 MHz CL15*F4-3000C15D-16GTZ4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws 4 3000 MHz CL15F4-3000C15Q-32GRKB4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16*F4-3200C16D-16GVK4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16*F4-3200C16D-16GVKB4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3333 MHz CL16F4-3333C16D-16GVK4Gb Samsung D-DieDualDoubleJedec Info
G.Skill Ripjaws V 3400 MHz CL16F4-3400C16D-16GVK4Gb Samsung D-DieDualDoubleJedec Info
K4A4G085WE (Samsung) Memory Chips:
G.Skill Trident Z 3000 MHz CL15F4-3000C15D-16GTZB4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZ4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZB4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16F4-3200C16D-16GVGB4Gb Samsung E-DieDualDoubleJedec Info
G.Skill Trident Z 3400 MHz CL16F4-3400C16D-16GTZ4Gb Samsung E-DieDualDoubleJedec Info
K4A4G085WS (Samsung) Memory Chips:
TeamGroup T-Force 3200 MHz CL16THRD416G3200HC16CDC014Gb Samsung S-DieDualDoubleJedec Info
TeamGroup T-Force 3200 MHz CL16THWD416G3200HC16CDC014Gb Samsung S-DieDualDoubleJedec Info
TeamGroup T-Force 3200 MHz CL16THBD416G3200HC16CDC014Gb Samsung S-DieDualDoubleJedec Info
H5AN8G8NAFR/H5AN8G8NMFR (Hynix) Memory Chips:
G.Skill Flare X 2400 MHz CL15F4-2400C15D-16GFX8Gb Hynix ?-DieSingleSingleJedec Info
G.Skill Trident Z 2400 MHz CL15F4-2400C15D-16GTZR8Gb Hynix A-DieSingleSingleJedec Info
Corsair Vengeance 2600 MHz CL16CMK16GX4M2B2666C168Gb Hynix A-DieSingleSingleJedec Info
G.Skill Ripjaws V 2800 MHz CL16F4-2800C16D-16GVG8Gb Hynix M-DieSingleSingleJedec Info
G.Skill Trident Z 3000 MHz CL15*F4-3000C15D-16GTZ8Gb Hynix A-DieSingleSingleJedec Info
G.Skill Ripjaws V 3000 MHz CL15F4-3000C15D-16GVKB8Gb Hynix M-DieSingleSingleJedec Info
Corsair Vengeance 3000 MHz CL15CMK16GX4M2B3000C158Gb Hynix M-DieSingleSingleJedec Info
Corsair Vengeance 3000 MHz CL15CMK16GX4M2B3000C158Gb Hynix ?-DieSingleSingleJedec Info
TeamGroup T-Force 3000 MHz CL16TLRED416G3000HC16CDC018Gb Hynix M-DieSingleSingleJedec Info
G.Skill Aegis 3000 MHz CL16F4-3000C16D-16GISB8Gb Hynix M-DieSingleSingleJedec Info
G.Skill Trident Z 3000 MHz CL16F4-3000C16D-16GTZR8Gb Hynix A-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZ8Gb Hynix M-DieSingleSingleJedec Info
G.Skill Trident Z 3200 MHz CL16*F4-3200C16D-16GTZR8Gb Hynix A-DieSingleSingleJedec Info
G.Skill Ripjaws V 3200 MHz CL16*F4-3200C16D-16GVKB8Gb Hynix M-DieSingleSingleJedec Info
Corsair Vengeance 3200 MHz CL16CMK16GX4M2B3200C168Gb Hynix ?-DieSingleSingleJedec Info
EVGA SuperSC 3200 MHz CL168GX-D4-3200-MR8Gb Hynix ?-DieSingleSingleJedec Info
Kingston Predator 3200 MHz CL16HX432C16PB3K2/168Gb Hynix M-DieSingleSingleJedec Info
Kingston Predator 3333 MHz CL16HX433C16PB3K2/168Gb Hynix ?-DieSingleSingleJedec Info
H5AN4G8NAFR/H5AN4G8NMFR (Hynix) Memory Chips:
G.Skill Ripjaws V 2400 MHz CL15F4-2400C15D-16GVR4Gb Hynix M-DieDualDoubleJedec Info
Kingston Savage 3000 MHz CL15HX430C15SB2K2/164Gb Hynix A-DieDualDoubleJedec Info
16GB (32GB Kit) Module List:
G.Skill Flare X 2400 MHz CL15F4-2400C15D-32GFX8Gb Hynix ?-DieDualDoubleJedec Info
Crucial Sport 2666 MHz CL16BLS2K16G4D26BFSC8Gb Micron B-DieDualDoubleJedec Info
G.Skill Ripjaws V 2800 MHz CL14F4-2800C14D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Trident Z 3000 MHz CL14F4-3000C14D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3000 MHz CL14F4-3000C14D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3000 MHz CL15F4-3000C15D-32GVR8Gb Hynix M-DieDualDoubleJedec Info
Corsair Vengeance 3000 MHz CL15CMK32GX4M2B3000C158Gb Hynix ?-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL14F4-3200C14D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL14F4-3200C14D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL15F4-3200C15D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL15F4-3200C15D-32GVK8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Trident Z 3200 MHz CL16F4-3200C16D-32GTZA8Gb Samsung B-DieDualDoubleJedec Info
G.Skill Ripjaws V 3200 MHz CL16F4-3200C16D-32GVK8Gb Hynix M-DieDualDoubleJedec Info
G.Skill Trident Z 3400 MHz CL16F4-3400C16D-32GTZ8Gb Samsung B-DieDualDoubleJedec Info
Some of the missing Thaiphoon Screenshots:
Trident Z:
  • F4-2800C15D-16GTZ
  • F4-2800C15D-16GTZB
  • F4-3000C15D-16GTZB
Ripjaws V:
  • F4-2800C15D-16GVSB
  • F4-2800C15D-16GVR
  • F4-3000C15D-16GVKB
  • F4-3000C15D-16GVGB
  • F4-3466C16D-16GVK
Many 16GB module (32GB kits) are still missing!
Reactions: Aenra and sydefekt
141 - 160 of 182 Posts
Hey guys so i just made an account because of this.
I recently downloaded Taiphoon burner and i noticed with 1 sticks that i got an CRC error.
It says that it got an error at the SPD Protocol section, see picture below.
Click here for pic: https://imgur.com/a/ou731Qj
What can i do to solve this? Sometimes i get a random black screen and i think this is because of this.... not sure tho..
related perhaps? https://www.hwinfo.com/forum/Thread-SPD-Checksum-Errors-w-HWiNFO64-Running
Have you stress tested the ram to check for errors?
I've had a few problems from overclocking my ram and writing errors to my drive because I didn't do the stress testing
Why is HWINFO showing 1.82 for VTT? On MSI b450 Tomahawk, 2133hmz? Funny thing is it shows the same at 2933mhz. is that anywhere near normal? Im reading that vtt should be about 1/2 of Dimm volts, and dim is like 1.26 max.
got an answer over at HWInfo forums. From Martin, its a generic reading and is not actually IMC/vtt. Hes removing it from next version.
· Hardware Enthusiast
For those who care about capacity: 128 GB on 1st gen Zen. (4 x 32 GB)
Not officially supported, but it seems to work anyway. It did take a couple BIOS updates though.
CMK64GX4M2D3000C16 - Micron B-Die
This ram is supposed to go in my 3950X build planned for this month. But since AMD pushed that back, I figured I'd try them in an older box. (I need to make sure they're not DOA.)
Anyone Able to Identify What Samsung IC This Is?
Been looking to upgrade to 32GB on the cheap while having a chance at decent performance via tuning and noticed this 32GB (2x16GB) DDR4-3000 CL16 kit of GeIL Evo Potenza model #GAPB432GB3000C16ADC being advertised as specifically designed for AMD Ryzen going on sale for $93, and I ended up getting it at Newegg's eBay store for a paltry $74 after 10% off from a coupon and 10% Bucks.
According to Newegg, this kit was first available on 10/07/19 so there's no reviews or info on the web about it and based on previous data points I surmised it would be Micron B-Die but it ended up being some type of Samsung IC after installing and checking BIOS and with the latest version of Thaiphoon Burner. XMP worked just fine. Unfortunately, Thaiphoon doesn't have a full part number for this IC, with a read on either slot giving part number K4AAG085W?-BCPB which I couldn't find any info for whatsoever. My assumption would be Samsung D-Die, but the info I can find for it online points to a part number with K4A4G085WD, and of course if it were E or S-die the part number would end with those letters. Instead, I just get a question mark. The manufacturing date for the DRAM is very recent, November 4-8/week 45 of 2019 which is less than 1 month ago. Anyone got any info on these? Thanks so much in advance. :thumb:
What Samsung Die is this?
G.Skill Trident Z F4-3600C15D-16GTZ
Works well at 3266 14-14-14-30 on my Ryzen 2700 / Asus Prime X370 Pro.
Thaiphoon reports Samsung D-die, but works well with the "Safe" B-die timings from "DRAM calculator for Ryzen".
G.Skill support says Thaiphoon is correct as dies can change between batches, but the calculator doesn't have any support for 3600 speed D-die, or single rank D-Die that big.
Does anybody know what die "K4A8G085WD-BCPB" is?
Hello guys and happy holidays.After having a lot of problems with a memory kit i bought(g.skill 4000MHz CL18-22-22-42), it cant even run on 3200 cl 16 on ryzen 2700x i found a new one at a good price but i have no ideea if it's b.die or not.I havent found any sure answers, one post on reddit that said its not b.die and not much info.
I wont recive the memory very soon, maybe at least 1 or 2 weeks from now.
This is the kit, i emailed g.skill and asked them if this is b.die but i'm sure it will take some time for them to answer.
https://www.gskill.com/qvl/165/168/1536218671/F4-3600C17D-32GTZKW-Qvl
· Graphic Card Addiction
According to this, it is B Die:
https://benzhaomin.github.io/bdiefinder/
Bookmark that site for future reference. :thumb:
Could you please add some more info to the OP on why we would want b-die, or some other "die"? "IC" has also not been defined.
From the "b-die finder" website it seems that b-die is significantly more expensive. Often twice as much or more. So it seems there needs to be a very good reason to pay more for b-die.
I JUST got a new Trident Z Neo kit: 3800C14-16GTZN. My kit also reports the same part number; K4A8G085WD. The 3800C14 kit works great at 14-15-15-34, but HwInfo reports it as Samsung D-Die; which I think is a mistake.
I'm running R9 3900x, F4-3800C14-16GTZN 16Gb kit dropped in and enabled xmp, MSI 1080ti, AsRock x570 Taichi
I suspect that it is mislabeled in Thaiphoon or something, because the numbers I am getting is insane.
I also read that we are mistaken in thinking that Samsung stopped producing ALL b-die instead of just one product line of it; I can't remember exactly where, but the source pointed out that the public twisted the wording around to make it seem like they stopped all production.
I don't think anything except b-die could run these INSANE numbers. I've got my Infinity Fabric/UCLK/MCLK 1:1 OCed to 1900; but it also works well on FCLK 1933, if a little unstable.
Edit:
Samsung B-Die is often touted as better than other ram dies (eg Hynix CJR, . The architecture of b-die makes it especially prone to having both high clock speeds AND low latency at the same time. Therefore; it is highly overclockable, and able to tighten timings very very well. No other ram right now can do both of those things as well as b-die.
There is also information going around that states that Samsung no longer makes b-die. This, of course affects people's assumptions about its scarcity, and therefore people will pay more for it because they think that there is only a finite amount of b-die left to purchase.
I have seen Samsung release information about b-die; and it seems that we might have been wrong, and Samsung probably still makes b-die, but they EOL (End of Life-d) a few of their b-die products, but not all of them.
Hi, so I just RMA's my Samsung B-Die F4-3200C16-16GVKA from January 2017, which was a VERY bad overclocker and received an identical kit which seems to have been manufactured April 2020.
Couldn't even do any frequency higher than it was rated for. As it's not listed like the GVK and GVKB dies I thought I'd post the Thaiphoon Burner readout here for you to add.
The only thing that changed in 3 years seems to be the manufacturer of the thermal sensor from ABLIC to OnSemi. I haven't tried overclocking the new kit yet.
Information about the manufacturing date has been taken directly from the label itself.
