Originally Posted by tytlyf that's normal for the voltages to change like that. Your bios temperature and your desktop temperature should NOT be the same. Seems you have a faulty sensor or something else...You bios should report 5-10c higher than what speedfan reports. This is due to your CPU not being "idle" when in the bios. Your cpu is under load in the bios. |
Originally Posted by Noob1ee Edit: hmm it idles at 43degrees celcious.. |
Originally Posted by tytlyf Is that in the bios or with a program? The big typhoon would probably fit, but you have to find out if it's supported on your motherboard. Most likely it is. I would head over to DFI-street.com and ask around for that board and it's compatability. I'm going to say yes, but check anyways. |
