1 - 2 of 2 Posts
hey all, i'm new to overclocking and i have a 3200+ Venice AMD and an ABIT kn8-ultra motherboard. i was following the guide on AMD overclocking on this website, and it told me that a safe temperature while running prime95 for the cpu was 45 degrees C. still it didn't tell me what the temp for the mobo should be. while running prime 95, the cpu is at about 48 degrees and the mobo is at 52 degrees. is this too high? if it is, what temperature should i be looking for? thanks for your replies.
Discussion Starter #2
i'm at the part of the process where i raised all my memory timings and upped the voltage a bit on the mobo. my fsb is at 240 right now and i'm trying to find the max fsb for my mobo. thx
1 - 2 of 2 Posts
