safe temp for x800 GTO?
796 10
i've had my gpu while scanning for artifacts in ati tool go up to 60 degrees ... i since put the settings down .... but i'm wondering where the safe temps end
1 - 11 of 11 Posts
I wouldn't worry about that one bit, 60c is a good load temp on a graphics card. You won't start running into problems until around 85c+ Graphics cards can take much more heat compared to processors..
hmmmm ..... really .... good to know .... now all i have to do is figure out if i can unlock or not
Do you have a pic of your ATi tool "hidden section"?
here ya go
Originally Posted by Diablo_MGSx2
here ya go
Locked
sorry
That is common with the new ones..
Locked
sorry
oh well ... i'm clocking it now .... i'm at 485 mhz for the core with no errors and 57 degrees for the past 5 minutes
Discussion Starter · #9 ·
Originally Posted by noneed4me2
My C3D GTO would get as high as 78 C under load at stock clocks and stock cooling, so i got an ATI silencer5.2 and now it never goes higher than 57 C under load and overclocked. Zalmans are great too and their releasing a newer one soon http://forums.techpowerup.com/showthread.php?t=8423 , don't know yet if it will fit x800 series card.
well its looking stable at 499.50/549 ran it for 10 mins so far with no problems with ati tool with a load temp of 61 .... i think its causing my cpu to heat up tho
i have my card stable @ 570/1300 and with 33°C on idle and 50°C on max. load..... this gives me headroom for v-mod..... i'm doing it next month and expecting core clock of 600MHz and more and temp. probably 10°C higher at load.... and even now i get 6900 points in 3dmark05.....
What fan are you using? That's a nice clock.
1 - 11 of 11 Posts
