1 - 3 of 3 Posts
So, I have started to over clock my CPU and was just wondering what temp. I should stay under. And do you change the ram speed in the BIOs?
Try to stay under 55 full load then you will have no probs..While youare ocing drop the ram by 1 divider in the bios ie if your running ddr 400 drop it to 333 then it wont get in the way of the cpu oc
You should try to keep you CPU under 50c under Load for AMD's<br><br>
About the RAM Speeds - You can change the RAM dividers + Other related information using most bios.<br><br>
If for some reason You cant find the options - Search Google for A64tweaker <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
1 - 3 of 3 Posts
