1 - 11 of 11 Posts
If it is maxing at 52°c after the test I wouldn't worry, though I would keep an eye on ambient temps, if that test was done on a colder day, those temps might not be indicative of what you will see mid summer.
1.6v
I would be nervous to run that 24/7, but I'm running mine at 1.55v with about the same temp over ambient. I never let it get 80 degrees in my room, but yes you should be just fine with those temps.
Originally Posted by Alkaline41;13047428
Was wondering if 52c at full load is fine for an amd 1090t.
The highest I have been able to get my chip is 4.2 with 1.6v at 52c doing 10 hours of prime95 torture test. The room is 80f.
Sounds good too me..but u think that 1.6 is too high of a voltage for 4.2..mine goes 1.48v stable 24hour prime..try to lower it and a tad ull see much better temps
But ur temps right now are great..
Temps are fine. Definitely keep it under 62 C, but keep it under 55 for maximum stability. Also, 1.6V seems kinda high, but it's fine for water and you're under the thermal limit.
Thanks and rep to you all.
I have tried lower temp but 1.6v is the stable point for 4.2ghz. I had either choice of lower temp at 4.0ghz with 1.45 or where I am at now.
btw This is my first time water cooling and I must say its extremely fun.
Does the extra 200MHz really help all that much? If not, I'd definitely drop it down to 4GHz w/ 1.45. It'll help increase the chips life.
1.66v on 4.6ghz suicide run...i got 4.3ghz at 1.56v...4.5ghz at 1.61v..
Yea that voltage for 4.2ghz way high...just my opinion.. But dont get me wrong ur temps are great...
1 - 11 of 11 Posts
