After update to 20h2 my pc start to randomly shutdown, when check event viewer i find error 7000 the problem was cpuz not able to lunch correctly. I went and uninstall the program and run a free cc cleaner try out to completely remove it, but the error still shutting down the pc randomly. I can't find any trace of the program what do i need to do. Buy a program remover software or there's any other way available.
Thanks
Thanks
