Hi all,
I have 3x Akasa Piranha front intake fans connected to the ASUS Maximus VIII Gene motherboard (CHA_FAN4) using a PWM 3 way splitter and 2x Akasa Piranha CPU fans connected using a 2 way splitter to CPU_FAN header, both are running the same fan profile in the BIOS however CHA_FAN4 fans are running 70-90RPM lower than the fans connected to the CPU_FAN header, is this normal?
Also, is it safe to connect 3 fans to the motherboard using a 3 way splitter or would that overload the fan header? The fan label at the back says 0.13A and I have checked the motherboard manual but it doesn't say the max fan power for chassis fan connectors.
Thanks
Thanks
