I'm picking up 2 Samsung 1TB F3's tomorrow, I want to give short stroking in RAID 0 a whirl. Note this drive will be for apps and data, my OS is installed on the X25-M ssd.
1) What size partition would you recommend?
2) SATA ports 1-5 on the Asus P5Q Pro are all controlled by the ICH10R? I can drop the F3's on two of these and set up in BIOS and I should be good to go?
Anything else I need to consider?
thx.
thx.
