I have a 226BW, original samsung model. So far it has worked beautifully, great monitor for an LCD.
Anyway, recently for no apparent reason, it has started to flicker very rapidly when I either first turn it on, or it comes out of a standby state after a significant period of downtime. The screen is practically unusable in this state because it is dim and flickering rapidly. I can't figure out anything I may have done physically to alter its behavior... it did start happening roughly around the same time I upgraded to the latest nvidia drivers, however it doesn't only happen in windows, it happens from a cold boot from the BIOS screen which would indicate it's not driver-related, right?
Anyway, the flickering continues for anywhere from 2 to 6 minutes or so, and at some point it randomly comes full on and works normally. Nothing I can do seems to influence how long it flickers for - I can change resolutions or brightness settings or launch a 3d game or turn it on and off and it doesn't matter... it's just going to randomly pick its own time to stop flickering.
Does anyone know what the cause might be, or any potential solutions? I don't want this monitor to die, it was hard enough to find originally (without getting a crappier subcontracted model of the 226bw). Should I just leave it on 24/7 and not let it power down?
I guess there's a possibility that it relates to the video card rather than the monitor - if you think that's likely then I can drag it to someone else's house and test it on their system. I should also mention that it's part of a dual setup with another 226 (the other one Chimei unfortunately) and it's set up as the primary monitor. The other monitor shows no signs of problems.
