1 - 10 of 10 Posts
Apparently these are cheaper versions of last year panels retailing at
300 USD for Samsung C27JG50.
400 USD for Samsung C32JG50.
C27JG50:
https://displaysolutions.samsung.com/business-monitor/detail/1282/C27JG50
C32JG50:
https://displaysolutions.samsung.com/business-monitor/detail/1284/C32JG50
At least we have these prices in Russia.
There are several reviews. Here is the Russian one if you can use Google translate:
https://3dnews.ru/974553
Basically these are the same as c32hg70 and c27hg70 but without Freesync, HDR, QLED and enormous stand.
Also these are approved to finally be completely flicker free by this and other one review.
I ordered 27 inch one and can post some early impressions. I have had c32hg70 previously.
You think 32 inch model is better? I have not heard anything bad about grey.
Yeah the C27HG70 is thoroughly tested even here, grey uniformity looks like someone beat it with their fists for a couple of hours before sending them off of the factory. C32HG70 didn't have such problems, but PWM and slower response times.
Discussion Starter #5 (Edited)
It seems quite fine in all areas except I feel like all colors are washed out and there is a grey tint on top of everything. Black is more like grey than black and it looks like grey color is all over all other colors. I have not seen anything like this on Samsung c32hg70, frankly speaking it was completely the opposite when colors were very bright. With this one I have to calibrate extra color +10 % in Nvidia control panel. I wonder if mine is defective or am I doing something wrong :)
So I should have listened to the guy above. It actually looks like this monitor has a dirty screen effect due to grey uniformity and it actually looks like it was beaten with fists I agree. I have not seen anything like this ever even on TN panels.
Overclocker
Same crappy panels as before?
Still curved, no thanks.
Now with even worse stand, relocated joystick to middle bottom, where as the old one was at a good position.
Still no handle up top in the redesigned plastic shell.
So they removed all the "goodies" from HG to make a "cheaper, business user oriented" variant called JG and sell those crappy panels in mass to different customers.
You're doing it wrong if you're adding software vibration to colors to get a fake pop. You should never touch those controls and make changes in software to the image.
You can see the disaster of C27HG70 in previous Samsung thread, I've posted many photos of 5 units and a comparison is linked in my signature with AUO's IPS.
Samsung curved HG in 27" is an unfortunate big mess up by Samsung, terrible dark gray uniformity, constant issues with dead/bright pixels, some units may be slower response time wise to a point of 31.5" variant that is unusable for almost anything but static images. Even 27" has blacks smearing in movies, website browsing, ... let alone games.
Adaptive sync range issues, now they remove it completely? Won't buy any monitor without adaptive sync, don't care if it's a cheapo Samsung PLS for 100 EUR or VA for 500 EUR thay both have adaptive sync or no deal. Their cheapo PLS do have adaptive sync, it's not a costs issue, never was.
Curved is not for gaming either, nor for movies, it sucks for desktop use, the #1 thing they should have removed and keep the other features was to make it flat and thus fix their crazy uniformity and defective rates. But no, they remove all that was good about it and keep the worst. Samsung...
I think there may also be JG52 variants, they've announced two JG at least over the last year. Stand maybe some feature are different, all are still curved because Samsung loves their stupid curved VAs.
Discussion Starter #7 (Edited)
Frankly speaking everything except colors is quite all right for the money. If not for colors this monitor could easily be recommended as a gaming monitor for around 300 USD since there is basically almost no competition but with that grey effect I can't tell for sure.
According to review on 3dnews, they ended up calibrating
Image mode — Custom
Brightness — 17 !!!!!!
Contrast — 75;
Sharpmess — 56;
Color temp — "Custom" (43/52/37);
Gamma — "Mode-2";
Repsonse time — Fastest.
I will set 17 today and share the results but it sounds ridiculously low lol. I wonder if it is the only way to remove some cheap illumination which replaced QLED.
Image mode — Custom
Contrast — 75;
Sharpmess — 56;
Gamma — "Mode-2";
No, it’s just that their reviewer, DEAD, always calibrates to 100 nits instead of the more widely used 120. His numbers are useless to you anyway, to be frank. The difference in the panels is too big. What’s 6500K at 100 nits for him might be something completely different for you.
Discussion Starter #9 (Edited)
I have checked all I can.
Never buy this monitor.
DONT EVEN THINK ABOUT GETTING ANY OF THESE TWO. THEY ARE DEFECTIVE FROM FACTORY.
Not a single sane company would make a panel that bad. It is worse than TN. I have no idea what to do with mine.
I think that some of their engineers went full ****** and made a grey panel instead of colorful one after many reviewers told that their previous CG panels were oversaturated.
Whoever made oversaturated or greyish panel like this should be FIRED FROM THIS ****TY SAMSUNG because I can't believe that a VA panel can be worse than 2007 level of TN colors. This is absurd.
Overclocker
There are JG52 in Europe and cheaper than JG50, no idea if those have adaptive sync or even JG50 has it.
Overall Samsung has struggled with their 1440p HG70 panels and these are the same or an evolution of with a cheaper backlight and overall build stripped of some features. Yes VA can be worse than TN in viewing angles, color wise etc. hmm depends on how much they mess up the backlight and calibration.
As always when buying any monitor, make sure you can easily and cheaply return it. If you can see it in person before buying, do it and use it as much as you can.
All these Samsung panels are nice on paper but often fail to deliver even minimum required quality. Curve is their #1 abomination that ruins most of the panels.
C27JG52 is around 300 EUR on Amazon.de and at least you get "free" return.
1 - 10 of 10 Posts
