samsung sfm 3200lw, external monitor
1371 Views 0 Replies 1 Participant Last post by  REDHAMMER999
hi, okay so I have this samsung sfm 3200lw. I have found that the monitor doesnt work... so how do I make it switch to an external monitor? I plugged one in and it wortks until it boots up windows and then it seems to go blank (maybe it switches back to the internal?) either way how do I get it to go back to the external one? Also when you press any of the keys on the keyboard when it's loaded into windows it makes a BIOS beep. however it does not do this if you press the FN + another key. is this just because there is no screen output?
there is a key whioch when combined with the FN key you should be able to switch between LCD/CRT? does this m,ean internal/external? if so it doesnt seem to do anything?
thanks
and reps for help.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
