1 - 4 of 4 Posts
hello,
ive just bought this monitor and i have a little problem, when i connect my pc through the HDMI cable to the screen it will also use the built in speakers.
i dont want to use the built in speakers, how do i do this?
how are they called? i had no idea ati had audio drivers.
Discussion Starter #4
ok, solved. just had to go to audio options and disable ATI HDMI audio.
its strange beause it still had my sound card as preferred soure... welll nvm. everything solved.
1 - 4 of 4 Posts
