San Ace 1011 supplier
365 Views 8 Replies 6 Participants Last post by  Marin
109P1212H1011
is this the right part number for the famed denkis?
1 - 9 of 9 Posts
hmmm...found a few of them with distributors at my work. have to call about a price though.
Originally Posted by twitch101
109P1212H1011
If I'm not mistaken, I think that is the model number for the older 1011 fans. I think the newest ones that everyone is carrying on about are the 109R1212H1011. I asked Marin about it and that is what he said he thought. He also believed that it should perform similar.
From what I can tell the physical differences appear to the be the slight shape of the blades and possibly the material the frame is made out of. I'm not 100% on any of this though so take it with a grain of salt.
Originally Posted by tofunater
Here are the new ones
That should be them. Probably a better idea to get these instead of the older 1011's; I got four of the newer San Aces for my A1200 (front intake) and imo they're better. The blades are thicker and have support at the bottom to give them more strength, which is good since the older Sanyo Denki fans were pretty fragile.
wow 80 bucks for fans
id have to sell my panaflos to help me out
Thanks for the link. I thought those were unobtainable.
What I've read the new ones have a slightly lower CFM but a higher static pressure so ideal for radiators
Just to mention now, the fans from Newark only come with tails so you'll need to pin them yourself (very easy to do).
1 - 9 of 9 Posts
