1 - 14 of 14 Posts
DTR Enthusiast
I've been interested in server computers for a while now and I've come to the conclusion to update my dream server. So now I have recently heard of that Sandy Bridge is now in servers. So my question is which is a good one to have and can it be OC'd? (Would like to keep it below $300)
DTR Enthusiast
Originally Posted by The_Hairy_Yak;15280781
Sandy bridge - e class CPUs have not been released yet...
Are you sure cause I can add to my cart.
DTR Enthusiast
Originally Posted by fventura03
what are your intentions with this server? do you need all that power?
Mostly e-peen but will be a future business server.
the lga 1155 SB xeons are the same silicone as the desktop with few changes
a) multiplier locked
b) some have had their igp surgically removed (the ones that end with a 0)
c) ecc support is turned on
other then that they are exactly the same, so unless you are getting a big pile of ecc ram there is literally no point in geting a sb xeon and if you actually were in desperate need of ecc ram you would be better off getting a 1100t and overclocking it since it is also ecc enabled and performs better OC'd then a non OC'd SB chip
DTR Enthusiast
Originally Posted by fventura03;15286894
oh, hehe, had to google that term, got it.
I had to do the same thing when I heard it lol
I'm sorry but for me I prefer Intel builds
Any chance on the other Xeons in 1366 that are OCable?
out of 1366 i would look into either W36** or X56** chips (the latter being the dual socket capable) but keep in mind if you go with dual socket there is only one motherboard that supports dual xeon overclocking (the ever so notorious sr-2), they are quite pricy tho
DTR Enthusiast
Discussion Starter · #12 ·
Hmm are you sure thats the only board cause I was looking forward to this one that way I could save money on my case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131378
Pretty much the only thing that set apart SB Desktop and SB Xeon is ECC RAM support. Just stick with Core i5/i7 unless you need ECC RAM support. SB Xeon on LGA1155 have their multipliers locked so no overclock for them.
If you insist on SB Xeon that can OC then wait for SB Xeon on LGA1355 and LGA2011 comes out.
1 - 14 of 14 Posts
