1 - 20 of 401 Posts
Looking to create a list of SB overclocks with their respective voltages.
Please state what sort of stress testing you've done at each clock rate.
(Thanks)
Examples:
Mine
i5-2500k 4.2GHz 1.28v Prime sfft 1 hour
i5-2500k 5.0GGhz 1.48v Prime sffft 1 hour Prime blend 1 hour Folding @ Home 7 1/2 hours
Board: Gigabyte UD4 LLC on
Image by Lutro0
https://spreadsheets.google.com/pub?key=0AqhwVC9Lw4S5dDRuRklnc0RZa0RRZmthTUFidHRjc2c&w=75h=500]SB Spreadsheet[/URL]
i7-2600k
Name Speed Voltage Batch Board
reflex99 5.40GHz1.49vL040B208P67A-GD55
tconroy1355.00GHz1.37v
Not a Good Idea5.00GHz1.38vL040B208P67A-UD7
cmeeks 5.00GHz1.39vL040B208P67A-UD5
gonX 5.00GHz1.47vL040B165ASUS P8P67 Pro
Agavehound4.80GHz1.32vL040B208ASUS P8P67 Pro
LJC 4.80GHz1.34vL040B165ASUS P8P67 Pro
kcuestag4.80GHz1.35v ASUS P8P67
rmp459 4.80GHz1.395vL040B705ASUS P8P67 Deluxe
ugotd8 4.80GHz1.40vL040B208BIOstar TP67XE
Sedyn 4.80GHz1.40vL040B255ASUS P8P67 Deluxe
cmeeks 4.80GHz1.42vL040B208P67A-UD5
nmanley 4.74GHz1.40vL040B705ASUS P8P67 Pro
Sedyn 4.73GHz1.365vL040B225ASUS P8P67 Deluxe
TheDream4.70GHz1.32vASUS P8P67 Deluxe
cmeeks 4.60GHz1.30vL040B208P67A-UD5
Sedyn 4.60GHz1.31vL040B225ASUS P8P67 Deluxe
aleiro 4.60GHz1.34vL041B741P67A-UD7
jackbrennan2008 4.60GHz1.26vP67A-UD7
gooddog4.50GHz1.30vASUS P8P67 Pro
soldierblue4.50GHz1.32vL040B705P67A-UD4
PaulWog4.70GHz1.42vL040B243P67A-UD4
DayoftheGreek4.70GHz1.37L040B705Asus P8P67 Pro
techheadtrevor5.02GHz1.424vL040B225Asus P8P67 Pro
rickss69 5.30GHz1.53vL042B215ASUS P8P67 WS Revolution
i5-2500k
ehpexs 5.3GHz1.48vL041B789ASUS P8P67
hamster3null5.00Ghz1.42vL040B671P67A-UD3
ckybam35.00Ghz1.495vL041B800ASUS P8P67 Pro
BallaTheFeared5.00GHz 1.50vL041B522P67A-UD4
TriBeCa 4.80GHz 1.416vL040B672ASUS P8P67-M PRO
compudaze4.8GHz1.390vGigabyte P67A-UD3
Capwn 4.80GHz1.40vL040B671Biostar TP67XE
Aytaç 4.74GHz1.42vP67A-UD4
cory12344.70GHz1.31vASUS P8P67 Pro
hamster3null4.70GHz1.35vL040B671P67A-UD3
i_hax 4.60GHz1.28vL041B527P67A-UD3
SovereigN74.60GHz1.30vASUS P8P67 Pro
Armastitium4.60GHz1.35vL040B671ASUS P8P67 PRO
Duguganu4.60GHz1.38vASUS P6T
IzorkX 4.50GHz1.28vASUS P8P67 Deluxe
hamster3null4.50Ghz1.26vL040B671P67A-UD3
Pauliesss4.50GHz1.30vAsus P8P67 Pro
Armastitium4.50GHz1.32vL040B671ASUS P8P67 PRO
CKtalon 4.60GHz1.28vL42B291Asus P8P67 Pro
Trew 4.20GHz 1.20vMSI P67-C43
i5-2500k 4.5ghz 1.29 V PRime 2 hours or so
Also, whatever happened to the warning that sandy bridge volts should be between 1.325 and 1.38 (somewhere there)? Also, whats the recommended PLL voltage? I have mine at auto for now with asus p8p67 pro.
From what I've seen I'd caution you that your reported voltage and the actual voltage may be two different things.
It seems ASUS boards are reporting voltage lower than other boards. Every person with an ASUS board - including yourself now has reported voltage far lower than what everyone else seems to be getting at the same clocks.
Please bare in mind that this doesn't mean it is, just something I have observed.
should also add if HT is on or off...
4.8g HT off. 1.34. Prime95 3hrs, IBT: 20 runs
4.5g HT on. 1.3 Same
I haven't tried to optimize, I just wanted to see what I could get below 1.35 with HT on and off.
I'm getting about the exact same. 1.29v under load. I'm debating on whether or not I should use extreme LLC. I heard it can degrade your chip?
4.6ghz, 1.296v, 50 Linx stable, and going on 2 hours of Prime95 as I type. I set my PLL to 1.85v. I've read you need 1.9 for 4.7ghz+ but I haven't pushed my chip that far yet. I also have all power saving features enabled.
http://www.overclock.net/intel-cpus/751860-intel-k-club-discussion.html
I have a chart already set up so everyone can compare instantly.
I have it set to extreme as I was following the newegg youtube guide from an asus rep. It seems cpu z does report a lower voltage from bios as I get 1.288 on load, 4.5 ghz.
Prime95 just failed after an hour and a half. Bumped it up to 1.31v. I never did full stability testing at 4.5ghz, but I passed 20 linx runs @ 1.25v (load).
Originally Posted by BallaTheFeared;12013226
Cory your voltage was at 1.34v in your previous screen shot...
Cpu-Z is more accurate. The Vcore drops under load because I only have LLC on medium for now. If I set it to extreme it doesn't change under load. It makes more sense to state the voltage under load since a higher idle voltage seems pointless?
Does anyone know if LLC degrades these chips?
Haha damn mine just failed too after I came back; an reboot happened which I assume a bsod occured (too low for a 4.5 I guess). I bumped it up to 1.31, cpu-z 1.56.2 reading 1.304 as of prime95 in blend testing.
You might want to add another 0.005 or two for a 4.6 to get a stable oc and than find the perfect low vcore by lowering it 0.005 a time.
Anyone know if these rams can be oc'ed at all?
EDIT: down to 1.30v from 1.31v with same 4.5ghz
if you are going to off HT why do you buy 2600k ?
Discussion Starter #16
Originally Posted by Digigami;12013495
Here.. easiest way is to just post my ppd/watt spreadsheet from my 2600k build; contains my voltage settings for 4 different speeds, gives you an idea how much more power it will pull once you OC also.
2600K PPD/Watt
*cough* Balla are you going to post your ppd numbers in my database? Pretty please?
My ppd is terrible, like 16k on my i5-2500k and 17k on my gtx 470.
Discussion Starter #18
Ahhh yes, I had a run in with ASUS LLC back on my AMD chips.
I remember being able to do 4.1GHz on a 965 with 1.2v whereas everyone else needed 1.45 or more.
I'd be careful if I was on an ASUS board - they report power voltage but temps and stability don't reflect the actual voltage being used.
1.47v during load, 1.45v in BIOS. 4.9 GHz HT on.
Still tweaking, done Prime95 for 5 minutes, but no crashes yet.
Discussion Starter #20
Here we go I found it: Notice my voltage, and my temps...
It was a rather large thread here on OCN trying to figure out why I was .1v or more below what everyone else needed.
It turns out it was because of LLC on the ASUS board, it would boot at lower voltage and report said lower voltage, but the actual voltage was far higher in Windows despite it not being reported as such.
It was all quite embarrassing to me to be honest.
Here is the thread: http://www.overclock.net/amd-cpus/826676-4017-mhz-oced-ph-ii-965-a.html
As I said it turned out to be an LLC issue, and the actual voltage needed with less LLC was around 1.46 I believe with the exact same temps.
1 - 20 of 401 Posts
