1 - 15 of 15 Posts
i'm having problems with this card.
i took of the cooler off and tried to get it running bare but couldn't get a screen. i just got my 480 later today and it booted fine.
does anyone know what could be causing the problem?
i recently had a gtx 285 in and then i put this 4870x2 in and got nothing. put the 480 in and it worked fine. what seems to be the problem?
The problem is you were running the gfx card without a heatsink... (i assume that what you mean by 'running it bare').
You probably killed it.
Discussion Starter #4
you can't kill a card by running it bare. thats the stupidest thing i have ever heard.
your saying that i was able to boot my gtx 295 hydro with the copper block and i don't even have watercooling and got it to boot.
should boot with power even though it was running bare. vrm chips weren't even hot
You had a large copper block to absorb the heat long enough to boot the machine. Running without ANYTHING on the gpu will kill it in seconds.
Edit : see what happens to some CPU's without a heatsink, then remember that GPUs get much hotter than cpu's.
Discussion Starter #6
well i'll try it with the hsf when i get back home. i assembled it again. but just getting a boot screen for 4-10 secs shouldn't kill the card considering none of the vrms were even hot with a touch. thermal paste was still applied.
although earlier i found some brown spots on the bottom of the card could that be something?
Discussion Starter #9
haha your telling me. my hydro was left on for more than 30 secs and it was still okay.
if all else fails i could always RMA luckily doesn't end till this year and if that doesn't work BAKE BAKE BAKE!
Music Producer
Originally Posted by The Master Chief
why did you buy a watercooled video card if you dont have watercooling...
that has to be the dumbest thing I've ever heard lol.
Maybe he got it for a steep deal?
Discussion Starter #15
yeah your right. it was a steal. i thought it came with one but it didn't so i took it anyways.
i bought an accelero tri cooler from a member off TPU supposidly to arrive in a couple of days for the 4870x2.
i come around these things from time to time its a sweet deal but i work too much to even mess around with these and i end up tossing them back to you guys. :]
1 - 15 of 15 Posts
