Sapphire 5670 - which version?? (Quick response needed)
357 Views 3 Replies 3 Participants Last post by  qadri
Hi guys,
I am currently upgrading my computer and was about to purchase a graphics card (the Sapphire 5670 recommended to me by folks here considering my budget) but I have seen there are a number of different versions with different product codes on this site: http://www.ebuyer.com/search?q=sapphire+5670&x=0&y=0
Which one should I order?
A quick response would be appreciated as I am ordering very soon.
Thanks
1 - 4 of 4 Posts
Sapphire HD 5670 1GB GDDR5 DVI HDMI DisplayPort PCI-E Graphics CardQuickFind Code: 259591 | Mfr part #: 11168-30-20GFree Delivery
Best memory for the cost! Everything else looks the same.
Go for the cheapest one. None of them are really that different. What's the resolution you plan on using it for? If it's below 1440x900 get the 512MB model and if it's above that then get the 1GB model.
Sorry I should have said that I was referring to the 512MB version (not the 1GB)
It's not for gaming but just for HD and to speed up the computer (especially multi-tasking). I'm not sure what you mean by resolution but I will be upgrading to a 21" monitor wide-screen monitor. So is this card sufficient?
It's the 512MB that has so many different versions.
1 - 4 of 4 Posts
