1 - 5 of 5 Posts
I've heard of some people having similar problems, but once they used the 13.2 drivers it ceased. Well, it hasn't for me.
Benchmarking in Heaven and Valley I've noticed small, sneaky clear objects flickering between objects and textures sometimes but no real "in your face" artefacts. Just low scores which I found out of the ordinary.
http://youtu.be/mgT38svFqW4 - Artefacts/Texture Flickering
heaven.jpg 85k .jpg file
pixels.jpg 811k .jpg file
What should be here ?
What resolution are you running ?? Have you tried with Valley 1.0 as well. That score seems really low for an 7970
Its at 1080p.
Valley I get around 2200 for the score.
I'm sending it back to the place I bought it from. I'm worrying they'll say nothing is wrong with it..
If valley is getting you 2200, then that is normal. How are your temps ? its could be that the card is throtling.
Temp is 57 degrees on full load. Furmark gets it to 72.
1 - 5 of 5 Posts
