1 - 14 of 14 Posts
Hi, I'm new here and this is my first attempt at overclocking, so please don't bite my head off if I'm overlooking something.
I have a Sapphire Radeon 9600XT 256MB card in my system and I've been trying to overclock it with atitool, but I'm having some trouble. I used the Max Core button and it takes about 2 minutes and tells me my max is 501.5 (stock 500). The memory overclocking is even worse, the most it will overclock is about .5. Am I doing something wrong? I don't have any extra cooling, just a single fan in my case, but I figured I could get more than this much...maybe I'm wrong.
I can raise my core a bit, up to 508.5, and it takes 20-30 seconds before it beeps, which I assume means it found an artifact. Memory is being more tempermental, it'll hardly raise at all before it gets artifacts after a second or 2.
Maybe I should try another program? I'm downloading rivatuner and powerstrip now, going to try them.
· Premium Member
Try manually and punch in 520 core, 315 memory, and save.
My ATI 9600XT doesn't oc that well either.
BTW: Welcome to OVERCLOCK.NET.
At the bottom of the page, look for "jump forum", scroll till you find video cards.
Lots of threads to pick through. gL
· Old school
If you are using new drivers that card, you should install some older drivers.
Well, I've managed to get my core speed up to 530, and my memory up to....304 -_- Not sure what the deal is with memory, just won't budge. Oh, this was from using ATI Tray Tools, after I got newest Omega drivers.
Have you tried setting the clocks higher then ATI tool recommends?.
It is possible that ATI tool false-alerts you, The second option is that the clocks of your card are BIOS-locked and therefore you must flash your VGA BIOS to change them.
· Premium Member
I have a sapphire 9600 pro. I don't use ATITool becuase i find it doesn't give me the best overclock. Download the Omega drivers and use their OC'ing tool.
1 - 14 of 14 Posts
