has any one experienced a problem with the sapphire ati 5770 cards, with holding stock core/mem settings within CCC?
cpu-z reports the gpu at 300/600
uninstalled all ati apps. drivers
swept with driver sweeper..
double check reg....
no matter what driver or CCC build issue still occurs...ati over drive does not hold stock settings,,even with recovery feature ticked.....gpu settings seem to float..and again cpu-z reports totaly diff. values...
only work around i found was to uninstall all ati apps. and drivers,,,
sweep with driver sweeper
install latest driver for the sappire radeon hd 5770...
and install ati tray tools...
the ati tray tools has a force clock settings.. option..
now cpu-z reports the correct values...also seems that the voltage was set at .95 were as the req. voltage setting is 1.125 with is also required to power up gpu to correct value....
all in all i am asking am i the only one who has had such a hassel with the card ? please reply it may make me sleep better...
