Sapphire Radeon 9600 256MB really OC?
1328 Views 16 Replies 7 Participants Last post by  batista
I overclocked my sapphire radeon 9600 256mb but i dont see any diff.
Core clock=364.5
Memory clock= 216.0
regular clocks
Core=324.00
Memory=182.25
note da this card is not 8x it only runs 4x.
Any idea?
1 - 17 of 17 Posts
what was your aquamark and 3dmark scores before and after
thats not much of an increase anyway, but keep going in ATiTool, and find your max core/mem
I dont know. How do i find out?
Another thing i used rage 3d to overclock it
first of go to www.guru3d.com and download aquamark 3 and 3dmark01 and 03 and 05 and put your card to standard clock settings and benchmark it then oc it again then see if there is a increse in the scores
Core clock=364.5
Memory clock= 216.0
regular clocks
Core=324.00
Memory=182.25
Any idea?
Why does it only run at 4x? Sapphire 9600's run at 4x/8x, does your mobo not support 8x? The reason I ask is you are loosing a lot of bandwidth running at 4x compared to 8x.
My mobo doesnt support it and the card is 4x max.
you cant have a 4x mobo thats just wrong i think its time for a upgrade
Which model Sapphire 9600 do you have? AFAIK, All of Sapphire 9600 series cards support 8X. Anyway I think that your biggest problem is that the card is running 4x.
ThE_GeNeRaL do i have to install the 3 version of 3dmark or just the latest ?
And yeah the upgrade is coming an ATI x800, amd [email protected] 2.2 1mb cache, 1gb ram, asus ke deluxe, 200gb hd.
get all of them!!!!!!!
I downloaded and i got higher scores after oc but i dont see any dif in the sims 2.
Thanks anyway i'm giving this pc to my sister so i'm just experimenting with this 1 'till i get my new 1. Thanks a lot ThE_GeNeRaL
Well the sims doesn't really rely on a fast video card to perform better. You would probably see a difference in an action game where the screen is changing constatly. Fps in the Sim, i would imagine, is kind of a non-factor.
Yeh you shoud try action or even a rally like NFS Underground
He will notice a big difference in the sims if he were to upgrade to an 8x board...the new sims is quite render intensive. But it is not FPS intensive as you guys have stated.
Your 9600 256 meg overclocks are good, about as high as your going to go with a non-pro...I have the identical card.
It works fine for me with all the new games, would love to upgrade, just dont have the cash at the moment.
If you get a relatively inexpensive board with 8x capabilities, you will like the card all that much more.
Thanks for ya help and yes with nfsu. I will see how it works with my new pc.
1 - 17 of 17 Posts
