1 - 8 of 8 Posts
I filled out a support request to see if they didn´t mind me changing the TIM,
and to my surprise they didn´t.
Dear Sir
It's fine, do not damage any hardware from the components. Thanks.
Regards
To post a response please go to the link below.
Link: http://www.sapphiretech.com/us/suppo...53102G8674448S
To create a new topic please go to the link:
Link: Create New Topic.
Thank You
Sapphire Tech Support
This will be the second time. The first board stopped working about a week after I applied MX2.
I´m not sure if it was something I did, or a freak coincidence. This time I thought I´d ask for some tips as it took a month to get the MB back from RMA.
Does the TIM type matter ? I have some MX2 and OCZ freeze.
This is the MB.
http://www1.sapphiretech.com/en/prod.../276image2.jpg
Thanks.
It doesn't matter what TIM you use, some will give you better temperatures but you'll be fine with something like what you have or Arctic Silver 5
I doubt the mobo dying was anything to do with what you did. I reapplied thermal paste to both my mobos in the last year due to adding a watercooling NB block and mine have been perfectly fine
I would remove the thermal pads and put some TIM down
Junglist
Just to add, AS5 is conductive, so be careful where you get it, you could potentially short the board and damage it.MX-3 or Freeze are safe
AS5 is capacitive not to be mistaken with conductive. Just figured Id clear that up.
Discussion Starter #8
Ok , I sorted the TIM mess out.
In all it´s naked glory
The TIM was caked on very thick and like hard plastic. Such a shame, going to all that trouble designing a nice heat sink and using crappy TIM.
Here you can see a manufacturing defect. This was in the same place on the first board as well, but it was split open slightly.
This is why I couldn´t replace the thermal pads with TIM as they were about 3mm thick
This was just a follow up really and a good excuse to throw a few photo´s in.I ended up using the MX2 and my temps dropped about 5-6c which I´m happy with.
1 - 8 of 8 Posts
