SATA 3 GB support
380 4
Ok kind of a stupid question but,does my MoBo support SATA 3Gb in raid 0?
Heres what I'm looking at.
1 - 5 of 5 Posts
This is sad I posted this same question on DFI-Street( Whet with the maker first)and 2 and a half hours later no replies and only 6 views.
I posted here(should have in the first place) and 4 min. later replies and 30+ views.
JUST goes to show it doesn't get any better than OC.net.
Thanks DataX.........Reps!
JUST goes to show it doesn't get any better than Overclock.net.
No problem
I am probably telling you things you already know, chances are (like my wd sata 2/300) you will be able to change a jumper to go to 150 compatibility mode if you need to, not that sata2 would make a large difference in a single setup..
1 - 5 of 5 Posts
