1 - 2 of 2 Posts
I have been trying to use these Push On SATA power connectors, (but I have been having a lot of trouble with them.
Is there a trick to pushing the wires in?
It seems like everytime I use one, it will bend the small connections inside the connector (the ones that make contact with the drive).
I have been careful about pushing the wires in and also tried pushing the wires into one connector and then after the cable has been notched, use a new connector, but it seems that after one or two uses some of the connections bend and short something out.
Any suggestions?
1 - 2 of 2 Posts
